10576Views38Replies
Author Options:
Can you make a regular trampoline be an in-ground trampoline? Answered
I have an above-ground trampoline that I want to take the base off of and make it an in-ground trampoline. Is this possible?
wkortum
wkortum
Best Answer 10 years ago
dissolve the limestone with acid
Dr. Pepper
Dr. Pepper
Answer 10 years ago
I never thought about that! I'll give you a *best answer* if you can tell me what acid to use.
wkortum
wkortum
Answer 10 years ago
hydrochloric acid isnt very strong i think, but it can dissolve limestone fairly easily so it might be worth a look.
Dr. Pepper
Dr. Pepper
Answer 10 years ago
I actually have some hydrochloric acid at my house.
wkortum
wkortum
Answer 10 years ago
Niiiiiiiiiiiiiiice!
try it! but be careful...
Dr. Pepper
Dr. Pepper
Answer 10 years ago
Yeah I also have some Fluoroantimonic acid too! Google it and see what it is!
ChrisR533
ChrisR533
1 year ago
U can always cut the legs
lemonie
lemonie
10 years ago
You mean by digging a big hole and putting the trampoline in that?
L
Dr. Pepper
Dr. Pepper
Answer 10 years ago
Well, not exactly. I want to keep the hole pretty shallow because I hit limestone when I dig 3 feet in the ground.
lemonie
lemonie
Answer 10 years ago
You have enough answers, I'm in general agreement with everyone else.
L
lemonie
lemonie
Answer 10 years ago
It doesn't read well. e.g. "Spread mortar in between the bricks to ensure that they stay in place"
L
Dr. Pepper
Dr. Pepper
Answer 10 years ago
That's ok. I just need to know the instructions.
lemonie
lemonie
Answer 10 years ago
Those words don't tell you how to build a masonry retaining wall. "Dig a 4 foot hole in the ground is about it", and we already knew that.
L
Dr. Pepper
Dr. Pepper
Answer 10 years ago
Ok? I'm really fine. I know how to build things.
DP
lemonie
lemonie
Answer 10 years ago
Be sure to give us an I'ble!
L
Burf
Burf
Answer 10 years ago
+1
rkbrumbelow
rkbrumbelow
10 years ago
It is possible, you will need to make certain the upper frame is well supported and that the void underneath is well drained. Remember, you will need to go as far down as the original stand was up, and you will not want the fabric or padding to be in contact with soil or moisture.
Dr. Pepper
Dr. Pepper
Answer 10 years ago
I don't want to keep the stand because I hit limestone when I dig 3 feet in the ground.
Kiteman
Kiteman
Answer 10 years ago
Compromise: dig down 3 feet, then use what you dig out to build a sloping hillock around the trampoline.
Dr. Pepper
Dr. Pepper
Answer 10 years ago
I want it to look good. I also want it to be ground level.
rkbrumbelow
rkbrumbelow
Answer 10 years ago
if you can only go down 3 feet and the trampoline is designed for 4 feet of clearance then you have a problem and could find yourself bottoming out in a rather sudden way.
hightekrednek2396
hightekrednek2396
Answer 10 years ago
you could put it a foot above ground
CamillaLuvzMusic
CamillaLuvzMusic
Answer 10 years ago
(refer to previous comment) "I also want it to be ground level."
nebih
nebih
Answer 10 years ago
Me too! Except it is 6" not 3 feet LOL
Dr. Pepper
Dr. Pepper
Answer 10 years ago
LLLLLLLLLOOOOOOOOOLLLLLLLLL!!!!!!! I don't know why I did that.
jeff-o
jeff-o
Answer 10 years ago
That might be a problem. Remember, the hole needs to drain when it rains or you'll end up with a big mud puddle. How tall is the stand?
Dr. Pepper
Dr. Pepper
Answer 10 years ago
About 4 feet tall.
craftyv
craftyv
10 years ago
When We went to Barcelona some years ago, we saw, for the first time ever trampolines set in the ground. There were several in a row and you paid (?) for 30 mins. The spaces underneath was only about 1-1.50 FT. When you jumped they were just like a conventional but were much safer. Great Idea.
mberg
mberg
10 years ago
you could also cut of the bars and put wood under it to make it stay up.
mberg
mberg
10 years ago
yes. my friends have one so i know how. you should dig a big hole so you can fit the entire trampoline in it. if you've done that correctly, it should look like its 2 inchs of the ground. then fill the sides with the dirt you have. this should work.
(first when your planing where to dig it. draw a line beside the bars that hold it up so that you get the right size of hole.)
frollard
frollard
10 years ago
My neighbor did just that -
just dug a cylindrical hole and put the trampoline in it on some treated lumber pilings, on gravel. I don't know if they did anything to retain the soil.
I've had another friend that poured a concrete foundation in the ground to full depth - trouble is neither of these deal with drainage - might need a sump pump.
Dr. Pepper
Dr. Pepper
Answer 10 years ago
Thanks! I really don't want to have to get a backhoe just to put in a trampoline (see my other comments about the limestone in the ground). I was thinking of just taking off the stand and getting a professional to help me set it up.
frollard
frollard
Answer 10 years ago
Trouble is they have that height for a reason - you can nearly hit the ground with the stock legs and a heavier-duty jumper...
