5231Views11Replies
Can you make your own Capacitor charging Circuit?
I have a Cap bank, but i need some way to charge it without using a camera circuit. I have pretty much every component that could be required, so if someone could please make a schematic (even if it's done in paint) that would be great. Would also be useful to anyone else making a cap bank as well. Thanks.
Best Answer 11 years ago
As steve says; a capacitor is just like a battery, it takes any power you put into it, or any load you put on it - you just need to come up with a suitable voltage.
http://www.angelfire.com/80s/sixmhz/flyback.html
from dc power you can use a flyback tranformer, a type of voltage multiplier to switch a dc current to make whatever voltage you want. The camera charger works the same way; thats why you hear it make that whining noise as it charges.
11 years ago
Thank you guys, i found out how now.
I may Also put up an instructable one day on how to make those super caps.
11 years ago
How many volts, how fast ?
Answer 11 years ago
I was thinking like 12v from a power supply, not too picky about timing as long as it's below about 2 minutes. I have to calculate my capacitance, but i just want to be able to put the power leads on and switch it to the load when near full.
Answer 11 years ago
whats the uF and the voltage of the capacitors?
Answer 11 years ago
not sure. i made my own supercaps and its pretty big, probably over 1 farad.
i don't know how to measure it. I have tested that it works with 12v without lots of heating.
Answer 11 years ago
How have you made a 1 FARAD cap with home made super caps. Charge it to 12V, put a 10K resistor across it, and time how long it takes to decay from 12V to 7.5 Volts. Then roughly Time=RC, so you can make a very simple measurement.
What voltage will your caps stand ?
Answer 11 years ago
i just said it will accept 12v, but the only way to know for sure is to purposely overload it. All i need is a simple circuit diagram, that will be great.
Answer 11 years ago
well the other way of knowing is to look at the side of each capacitor and read the lowest voltage. Then that voltage is the max voltage for the capacitor bank.
Answer 11 years ago
If its only a 12V bank, find a 12V PSU, limit the charging current with a series resistor: job done.
The "camera charger" is usually for high voltage strike caps for the flash tube, which is what I thought you meant anyway.
Answer 11 years ago
will a boost converter work?
