105Views5Replies
Author Options:
Can you power an LED diode using headphone wiring? Answered
If I were to cut up a pair of headphones for the wiring, would I be able to us them to power an LED diode and connecting one end of the chopped off wiring to the LED and the other to a 9V battery. Would it work?
-max-
-max-
4 years ago
Yup. Did something similar for a quadcopter LEDs on the arms.
-max-
-max-
Answer 4 years ago
For a 9V battery, it would be good to have a few LEDs in series rather than just one or in parallel to maximize efficiency and less losses on a current limiting resistor. 3 red/orange/amber in series, or 2 white/violet/blue/green in series would proably work best.
iceng
iceng
4 years ago
You can use a single two or three pin bi-directional RED / GRN LED and a couple of series resistors across working each earphone giving you mostly yellow varying intensity as audio volume varies... At low frequencies you may see a preponderance of red or green...
ubdussamad
ubdussamad
4 years ago
It'll work , you just gotta be careful about soldering cause they're hard to solder. The easy way to solder will be , first burn the end of the wire (coming out of the core red/green/golden) about a cm long. then brush out the carbon left from the burned insulation then solder it by using flux for perfection.
steveastrouk
steveastrouk
4 years ago
Yes, it will be fine. You need a resistor to protect the LED too.
