1424Views5Replies
Can you put SCR's in parallel?
The title said it all. The reason I want to do it is because I want to discharge a capacitor bank into a coilgun, etc, using SCR instead of a large switch. The surge current form the capacitor bank is approximately 400 amps and the SCR's I have can handle surge current of 160 amps, can I put a few of those in parallel to handle 400 amps?
Best Answer 10 years ago
Which SCR are you using ?
I'm not sure if an SCR will current share nicely, like a saturated Mosfet will.
Steve
Answer 10 years ago
Having reviewed it, I suspect you can only really share SCRs by adding dropper resistors.
Answer 10 years ago
The SCR I want to use is BTA600BW, and what is a dropper resistor? I never heard of it before...
Answer 10 years ago
Its a current sharing resistor, you put them in series with the cathode or anode of your parallel connected SCRs, they allow the devices to current share.
You'd be MUCH better getting a better SCR.
Steve
Answer 10 years ago
Okay, Ill try do a few experiments and save up for a better SCR, thanks! :)
