27126Views9Replies
Author Options:
Can you turn a laptop LCD screen into a standard LCD Monitor / replace another brand laptop screen? Answered
My laptop is a Dell Latitude CPi and is INCREDIBLY old. It was made for Windows NT / 9x systems. The laptop itself no longer powers on for some reason, but the LCD might be useable. Instead of getting a new LCD for $100 or replacing the cracked screen on my acer laptop for $600+, I'm wondering if it's possible to convert the screen into either an LCD screen, a Cintiq-esqe tablet display (where there's probably a USB and monitor cable) or, if it can be used on an acer 5520 laptop (the screen is cracked and using it on the same monitor I need for my PC isn't the easiest thing).
gmxx
gmxx
11 years ago
Ive answered this question a number of times.... PLEASE SEARCH before posting. Anyways... for several hundred dollars, you can buy the controller board for the monitor. these are used to test lcd screens before shipment. For the laptop, these is a slim chance it would work. Assuming the lcd screens are: -the same size -the same model it should work. I might say that even if the screen is the same brand, it might work. It couldnt hurt to try.
anthonyloprimo
anthonyloprimo
Answer 11 years ago
The dell screen (referred to here on out as the "old screen") is a 4:3 ratio screen, and I think the max resolution is 1024x768. The acer screen (referred to as the "new screen") is a 16:10 (widescreen) and is something much larger. An external LCD will work, and adjust to any size (the LCD is a 1440x900 size). The brand is different (of course) and the old screen is much smaller than the new screen. it's also far smaller. Even if it can't exactly work the same (aka no swiveling and such) I wouldn't mind since I can make some kind of personal stand or something. As long as I wouldn't have to pay 600+ to replace the screen.
LizakIT
LizakIT
Answer 10 years ago
I can replace the screen for you for about $180. www.lizakit.com
gmxx
gmxx
Answer 11 years ago
its not so much the laptop brand, as it is the model of the screen. My old HP laptop used a samsung lcd screen. If the two lcd screens are the same brand, it might work. Your laptop probably wont ever be portable again if the lcds arent the same size.
LizakIT
LizakIT
10 years ago
Yes. You can turn your laptop screen into a standard LCD monitor to use with your for example desktop computer. Just go to eBay and look for this seller: "njytouch". Or click here: http://stores.ebay.com/njytouch?_trksid=p4340.l2563.
He sells control boards for about $30. I have one from him and its working great.
Hope this helps.
Niwaka3
Niwaka3
10 years ago
Technically you can turn your old laptop LCD into external LCD monitor by attaching controller board, DC-AC inverter and power supply. Those parts are available from Aitendo in Japan. Aitendo is a specialized shop for LCD parts for reuse.  Since the shop deals with domestic customers, you need to contact the shop and inquire possibility of export.
brokengun
brokengun
11 years ago
I had this idea a while back. Basically it would be nice if there was some sort of more standard connection they used so perhaps someone would come out with a cheap board to connect various LCDs to VGA cables. However, all of them are very different so doing what you mentioned is possible but probably time consuming and overall not worth it. Especially now that external LCDs are falling in price.
anthonyloprimo
anthonyloprimo
Answer 11 years ago
Yeah, I know. I already see great monitors that are under 100. Unfortunately the call for a dual-monitor set up isn't as strong as I would normally need (and I'd current'y use it for one laptop, while the other one is used for the other computer) but I'd like to do it cheap as possible, mainly because it's not a MUST have thing. Just a convenience. but from these comments and what I've been finding more and more... It's looking like it isn't worth it.. Not even to try and make it into a Cintiq-styled thing.
bassbindevil
bassbindevil
11 years ago
Or, ask around and you can score broken LCD monitors for nothing. They're often easy to fix; I've fixed two so far for less than $25 in parts (including postage). (One was lying next to a recycling dumpster, the other I got from a wanted post on Freecycle.) They often just need some capacitors replaced., and bad caps are easy to identify because they're swollen or burst. Badcaps.net has a forum dedicated to monitor repair.
