1160Views3Replies
Author Options:
Can you zap a 19.2 V drill battery using a jumper cable from a car battery? Answered
can you use a 12V car battery to resurrect a dead 19.2Volt drill battery
Tags:battery
Quincy8Boy
Quincy8Boy
11 years ago
I was going to try and put a load on my 18V cordless drill battery to run it down.  I was'nt  thinking very well.  No coffee.  And shorted it out.  This consistently bad battery is now running at least a minute instead of 10 seconds..  Interesting...
klee27x
klee27x
11 years ago
Well, first off it must be a NiCd battery, not NiMh. Then, the problem with the battery must be that is does not hold a charge for long. A common cause is "dendritic" fingers, which are like microscopic shorts in the cells. Applying a large current through the battery in brief pulses can melt these dendritic growths (think of them as very thin fibers). But for this to work, you need to open the battery, and apply these pulses to the individual cells within the battery. Applying 12V to a 19.2V battery won't accomplish the intended result.
frollard
frollard
11 years ago
Probably - in short bursts, and correct polarity - thats all the welder trick does, but thats at a few volts and a hundred amps... Car battery should do nicely.
