3551Views8Replies
Author Options:
Canada Amateur Model Rocketry? Answered
I've recently been looking into model rocketry, and was excited at the prospect of making and testing my own small sugar rocket motors. I've done quite a bit of research, and have discovered that many of the oxidizers i would need to use are not available in Canada (ex. KNO3, ammonium nitrate etc...). The only option I discovered was to synthesize KClO3, which I'm not interested in considering how dangerous and unstable it seems to be.
I was wondering if any fellow Canadians have found anything that can be used as a substitute/any way for me to pursue this as a hobby without buying motors pre-made, which I'm not interested in.
Any help is appreciated.
Jacob1067
Jacob1067
4 years ago
You may purchase any of the restricted components from the restricted components list if you do not create Restricted component products. I guess that's the same as making R-Candy ☹️
Jacob1067
Jacob1067
Answer 4 years ago
wait I think we can still make R-candy because we are not selling it.
Jacob1067
Jacob1067
Answer 4 years ago
Problem solved: ???
NicholasR38
NicholasR38
5 years ago
potassium nitrate can be legally purchased from chemical supply company's, as long as the amount is 25 kg or less. Alpha chem carries it for 340 dollars for 25 kg They also carry a small amount but that is very expensive.
MakeShiftMaker
MakeShiftMaker
6 years ago
ok i was in the same situation as you it turns out that some canadian tiers sell stump remover (potassium nitrate) and this is what i use to make b.p or rocket fuel you might need to ask around a few stores though its called
Falling Leaf Stump Remover
MakeShiftMaker
MakeShiftMaker
Answer 6 years ago
i will post a instructible on the moters i make later when i have time
TonyL9
TonyL9
Answer 5 years ago
Which Canadian Tire location carried it when you asked?
mpilchfamily
mpilchfamily
7 years ago
There is a reason you don't find much info about making your own motors. For one it's dangerous and 2 it can be used to make bombs. If you want to pursue rocketry then you will need to work with the motors that are available and focus more on the design and function of your rocket. Maybe explore using small jet like engines using liquid fuel to get your initial launch and move to the solid motors for the higher altitudes. Multi stage rockets are what the big dogs play with.
