318Views2Replies
Author Options:
Can't find the right pins on flyback transformer Answered
 I used various guides to find the negative 0V pin but all outputs give the same values. What can I do to find it?
It's one of those 'new' transformers.
Also, my transformer to test the thing and use the multimeter is about 14VDC (and the readings when testing give about 16V :P).
Should this work? As I live in Europe it should run on 240V.
Something else regarding this:
Do I really need to make a circuit driver for it or can I use the onboard waveform transformer thingy too?
And, if I get this thing to work, could I make a 2N3055 driver but with a different transistor?
(I have a IRF630N transistor, would that work? I've also got  C546B and C556B transistors....help!)
steveastrouk
7 years ago
A flyback transformer does NOT WORK ON MAINS. DO NOT TRY IT.
What do you mean by "new " transformer ?
YOu need to make a driver for it, probably.
icengsteveastrouk
Answer 7 years ago
+1
snateraar should always wear safety glasses
that robot has DANGEROUS thinking
