142Views3Replies
Author Options:
Capacitor problem Answered
I needed a 2.2 and a 10 uf capacitor to make a metal detector, but the values printed on my capacitors are not less than 5. I want to find that if the values on the capacitors are in uf, nf or pf. And if they are none of them.
iceng
iceng
Best Answer 6 years ago
Sounds like you don't know a condenser from a capacitor.
Capacitors store charge between two conductive usually thin foil plates
The bigger the area the more charge in micro farads uF
Some capacitors called electrolytic use chemistry to increase the uF numbers
these usually are only used on DC direct current and have a polarity plus side that must be observed or there will be smoke and fire.
The parallel and series wiring is described in the pictures I made just for you.
Notice the symbolic plate sizes represent the capacity equivalence changes.
Good luck and be careful :-)
A
tanyutsharma
tanyutsharma
Answer 6 years ago
The batteries of my camera were finished, so I drew one. It is exactly the same expect for the comic effect.
iceng
iceng
6 years ago
If you take two 5 capacitors in series they will become a 2.5 uF capacitor.
Then if you take two 5 capacitors in parallel they will become a 10 uF capacitor.
tanyutsharma
tanyutsharma
Answer 6 years ago
What do you mean by 'in series' and 'in parallel'?If possible add a pic.
