Change a 7 seg display from CC to CA in code?
How can i do this?
//_____________________ fuse.c
#define F_CPU 8000000UL
#include <avr/pgmspace.h>
#include <avr/eeprom.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define _REVERSE
#define _OPT_BUTTON_
. document tab-stop set to 4, best viewed w/ vi set to ":set ts=4"
. description
this project is created so that if i could revert the RESET fuse change and flash via
SPI again.
. features
. reads device signature and hi-low fuses for hi-voltage serial programmable attinys
. reset hi-low fuses to factory default on target devices
. layout to drop-on attiny13, attiny25/45/85 8 pin devices targets
. attiny24/44/84 targets needs additional breadboard and jumper wires
. standalone operations, fuses show on 7 segment display
. project fuse setting
avrdude -c usbtiny -p t2313 -V -U lfuse:w:0xe4:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m
. parts list
. attiny2313
. 4x7 segment LED display
. 1k resistor x 2
. 2n2222 NPN transistor or equivalent
. 78L05
. mini breadboard 170 tiepoints
. +12V battery source
. opearation
. place 8 pin target device on breadboard
. for 14 pin targets, jumper wire to breadboard
. apply 12V power
. display shows device name upon identification
. press and release button to cycle display content
. displays device name, fuse hi bits, fuse low bits and fuse extended bits
. long press and release button to reset fuse to factory default
. references and related projects
. datasheets
. avrdoper http://www.obdev.at/avrusb/avrdoper.html/
. mightyohm http://www.mightyohm.com/blog/2008/09/arduino-based-avr-high-voltage-programmer/
Gd 12V
Gd Rt V+ Ck MI MO (tinyusb programmer)
| . . . . . I . . . . . . . . . . . | [I]n (78L05)
| . . . . C . . . . . . . . . . . . | [C]ommon
| . . . . . . O . . . . . . . . . . | [O]ut
| (v)(d)(b)(c) +--------o (v) . . . . . (d)(c) . |
| +--+--+--+ | o +--+-(1)-A--F-(2)(3)-B--+--+ . |
| |+ | 1k | |+ b7..6..5..4..3..2..1..0 d6| |
| | -| | 1k|R d0..1 a1..0 d2..3..4..5 -| |
| +--+--+--+ o | +--+--+--+--+--+--+--+--+--+ . |
| . . . . . o - - E D (.) C G (4) - - . |
| o--------------o . . . . . . . . . . . |
| . (a) . E B C . (a) . . . . . . (b) . . | EBC of 2n2222
| . . . . . . . . . . . . . o--B--o . |
(p)(p) join (p)(p) during programming
SDO SDI
|+ SII |
|R -|
SCI
#define HIV _BV(7) //b7 .. RESET
#define VCC _BV(6) //b6 .. (v)
#define SDO _BV(0) //b0 .. (d)
#define SCI _BV(0) //d0 .. (a)
#define SII _BV(5) //d5 .. (b)
#define SDI _BV(6) //d6 .. (c)
#define BUTTON_DDR DDRD
#define BUTTON_PORT PORTD
#define BUTTON_PIN _BV(4)
#define SEG_A_PB _BV(5)
#define SEG_B_PB _BV(1)
#define SEG_C_PB 0x00
#define SEG_D_PB 0x00
#define SEG_E_PB 0x00
#define SEG_F_PB _BV(4)
#define SEG_G_PB 0x00
#define SEG_d_PB 0x00
#define DIGIT_0_PB _BV(6)
#define DIGIT_1_PB _BV(3)
#define DIGIT_2_PB _BV(2)
#define DIGIT_3_PB 0x00
#define SEG_A_PD 0x00
#define SEG_B_PD 0x00
#define SEG_C_PD _BV(2)
#define SEG_D_PD _BV(7) // d.7 maps to a.1
#define SEG_E_PD _BV(1)
#define SEG_F_PD 0x00
#define SEG_G_PD _BV(3)
//#define SEG_d_PD 0x00
#define SEG_d_PD _BV(6) // d.6 maps to a.0
#define DIGIT_0_PD 0x00
#define DIGIT_1_PD 0x00
#define DIGIT_2_PD 0x00
#define DIGIT_3_PD _BV(4)
#ifdef _REVERSE
#define HOLD_DDR_VAL 0x60
#define HOLD_VAL 0x40
#else
#define HOLD_DDR_VAL 0x18
#define HOLD_VAL 0x08
#endif
#define SEGS_STAY(v) \
(((v & _BV(6)) ? 1 : 0) +\
((v & _BV(5)) ? 1 : 0) +\
((v & _BV(4)) ? 1 : 0) +\
((v & _BV(3)) ? 1 : 0) +\
((v & _BV(2)) ? 1 : 0) +\
((v & _BV(1)) ? 1 : 0) +\
((v & _BV(0)) ? 1 : 0)) | 0x40
#define SEGS_PORT_DET(p, v) \
(((v & _BV(6)) ? SEG_A_P##p : 0) | \
((v & _BV(5)) ? SEG_B_P##p : 0) | \
((v & _BV(4)) ? SEG_C_P##p : 0) | \
((v & _BV(3)) ? SEG_D_P##p : 0) | \
((v & _BV(2)) ? SEG_E_P##p : 0) | \
((v & _BV(1)) ? SEG_F_P##p : 0) | \
((v & _BV(0)) ? SEG_G_P##p : 0))
#define SEGS_PORT(v) {SEGS_STAY(v),SEGS_PORT_DET(B, v),SEGS_PORT_DET(D, v)}
#define SEGS_B (SEG_A_PB|SEG_B_PB|SEG_C_PB|SEG_D_PB|SEG_E_PB|SEG_F_PB|SEG_G_PB|SEG_d_PB)
#define SEGS_D (SEG_A_PD|SEG_B_PD|SEG_C_PD|SEG_D_PD|SEG_E_PD|SEG_F_PD|SEG_G_PD|SEG_d_PD)
#define DIGITS_B (DIGIT_0_PB|DIGIT_1_PB|DIGIT_2_PB|DIGIT_3_PB)
#define DIGITS_D (DIGIT_0_PD|DIGIT_1_PD|DIGIT_2_PD|DIGIT_3_PD)
#define USED_B (SEGS_B|DIGITS_B)
#define USED_D (SEGS_D|DIGITS_D)
___a__
f| | b
___g__
e| | c
___d__
//_____________________ abc defg
#define LTR_0 0x7e // 0111 1110
#define LTR_1 0x30 // 0011 0000
#define LTR_2 0x6d // 0110 1101
#define LTR_3 0x79 // 0111 1001
#define LTR_4 0x33 // 0011 0011
#define LTR_5 0x5b // 0101 1011
#define LTR_6 0x5f // 0101 1111
#define LTR_7 0x70 // 0111 0000
#define LTR_8 0x7f // 0111 1111
#define LTR_9 0x7b // 0111 1011
#define LTR_A 0x77 // 0111 0111
#define LTR_b 0x1f // 0001 1111
#define LTR_C 0x4e // 0100 1110
#define LTR_d 0x3d // 0011 1101
#define LTR_E 0x4f // 0100 1111
#define LTR_F 0x47 // 0100 0111
#define LTR_P 0x67 // 0110 0111
#define LTR_G 0x5e // 0101 1110
#define LTR_n 0x15 // 0001 0101
#define LTR_r 0x05 // 0000 0101
#define LTR_t 0x0f // 0000 1111
#define LTR__ 0x00 // 0000 0000
uint8_t EEMEM digit2ports[][3] = {
SEGS_PORT(LTR_0), SEGS_PORT(LTR_1), SEGS_PORT(LTR_2), SEGS_PORT(LTR_3),
SEGS_PORT(LTR_4), SEGS_PORT(LTR_5), SEGS_PORT(LTR_6), SEGS_PORT(LTR_7),
SEGS_PORT(LTR_8), SEGS_PORT(LTR_9), SEGS_PORT(LTR_A), SEGS_PORT(LTR_b),
SEGS_PORT(LTR_C), SEGS_PORT(LTR_d), SEGS_PORT(LTR_E), SEGS_PORT(LTR_F),
SEGS_PORT(LTR_r), SEGS_PORT(LTR_P), SEGS_PORT(LTR_G), SEGS_PORT(LTR_n),
SEGS_PORT(LTR_t), SEGS_PORT(LTR__),
enum {
POS_0, POS_1, POS_2, POS_3, POS_4, POS_5, POS_6, POS_7,
POS_8, POS_9, POS_A, POS_b, POS_C, POS_d, POS_E, POS_F,
POS_r, POS_P, POS_G, POS_n, POS_t, POS__,
#define ST_HOLD 0x80
#define ST_PRESSED 0x40
#define ST_BUTTON (ST_HOLD|ST_PRESSED)
#define ST_TICKED 0x20
#define ST_12HR 0x10
#define ST_REFRESH 0x08
#define ST_BUZZ 0x04
#define ST_SETUP 0x03
#define ST_SENSE ST_BUZZ
volatile uint8_t busy=0;
volatile uint8_t state=ST_REFRESH|ST_12HR;
volatile uint8_t dim=1;
uint8_t pos=0, stays;
uint8_t mode=0;
#ifdef _OPT_SENSE_
uint16_t charged=0;
#endif
uint16_t button=0;
uint16_t clicks=0, ticks=0;
//_______________________ ticks per second and devired values
#define TPS (F_CPU/256)
#define TPS_2 (TPS/2)
#define TPS_4 (TPS/4)
#define LONG_HOLD (TPS/3)
#define NUM_DIGITS 4
static const uint8_t digit_mapb[] PROGMEM = { 0x40,0x08,0x04,0x00 };
static const uint8_t digit_mapd[] PROGMEM = { 0x00,0x00,0x00,0x10 };
//_________________ list of porta..c,ddra..c,stay * number_of_digits
uint8_t output[3 * NUM_DIGITS];
uint8_t *ioptr = output;
uint8_t dot = 0x00;
//__________________________________________________
ISR(TIMER0_OVF_vect) {
clicks++;
if (clicks >= TPS) {
clicks = 0;
state |= ST_TICKED;
ticks++;
}//if
if (stays & 0x0f) { stays--; return; }
stays >>= dim;
DDRA &= ~(USED_D>>6);
DDRB &= ~USED_B;
DDRD &= ~(USED_D&0x3f);
PORTA &= ~(USED_D>>6);
PORTB &= ~USED_B;
PORTD &= ~(USED_D&0x3f);
if (stays) { stays--; return; }
if (busy) return;
#ifdef _OPT_BUTTON_
//___________ scan button
PORTD |= BUTTON_PIN;
_delay_us(1); // allow pull-up to settle
if (PIND & BUTTON_PIN) {
if (button) {
if (button > 30) {
//_________ released
if (button > LONG_HOLD)
state |= ST_HOLD;
else
state |= ST_PRESSED;
stays = 0x14;
}//if
}//if
else {
stays = 0x10;
}//else
button = 0;
}//if
else {
//_____________ pressed
button++;
if (button > LONG_HOLD) { // show long hold
#ifdef _REVERSE
DDRB |= HOLD_DDR_VAL; PORTB |= HOLD_VAL;
#else
DDRD |= HOLD_DDR_VAL; PORTD |= HOLD_VAL;
#endif
}//if
}//else
PORTD &= ~BUTTON_PIN;
if (state & ST_BUTTON) return;
if (button) return;
#endif
#ifdef _OPT_SENSE_
if (!charged && (state & ST_SENSE)) {
state &= ~ST_SENSE;
DDRB = 0x00; PORTB = 0x00;
DDRD = 0x00; PORTD = 0x00;
_delay_us(1);
//_________ charge sensor led
charged = 1;
//SENSE_CHARGE
DDRA |= SEGS_D>>6;
PORTA &= ~(SEGS_D>>6);
DDRB |= SEGS_B;
PORTB &= ~SEGS_B;
DDRD |= SEGS_D&0x3f;
PORTD &= ~(SEGS_D&0X3f);
DDRB &= ~0x44;
PORTB |= 0x44;
//DDRB &= ~_BV(6);
//PORTB |= _BV(6);
//_delay_us(1);
//asm volatile("nop\n\tnop\n\tnop\n\tnop\n\t"::);
//asm volatile("nop\n\tnop\n\tnop\n\tnop\n\tnop\n\t"::);
//while (!SENSE_BUTT);
//PORTB &= ~_BV(6);
while (!SENSE_ALL);
PORTB &= ~0x44;
return;
}//if
#endif
//___________ load segments
uint8_t portd = *ioptr++;
uint8_t portb = *ioptr++;
uint8_t porta = portd >> 6;
portd &= 0x3f;
//uint8_t mapb = digit_mapb[pos];
//uint8_t mapd = digit_mapd[pos];
uint8_t mapb = pgm_read_byte(&digit_mapb[pos]);
uint8_t mapd = pgm_read_byte(&digit_mapd[pos]);
DDRA |= porta;
DDRB |= portb | mapb;
DDRD |= portd | mapd;
#ifdef _REVERSE
PORTA |= ~porta;
PORTB |= ~portb & mapb;
PORTD |= ~portd & mapd;
#else
PORTA |= porta;
PORTB |= portb & ~mapb;
PORTD |= portd & ~mapd;
#endif
stays = *ioptr++;
if (stays && (state & ST_SETUP) && (clicks / TPS_2) &&
((pos == (state & ST_SETUP)) ||
(!pos && !(state & 0x02))))
stays = 0x08;
pos++;
if (pos >= 4) {
pos = 0;
ioptr = output;
}//if
void seg2port(uint8_t bcd, uint8_t which) {
if (which & 0x40) {
//_____________ bcd entry, do 2nd digit 1st, then 1st digit
which &= 0x0f;
seg2port(bcd&0x0f, which+1);
bcd >>= 4;
}//if
uint8_t *pp = output + which * 3;
uint8_t offset = 3;
busy++;
do {
*pp++ = eeprom_read_byte(&digit2ports[bcd][--offset]);
} while (offset);
busy--;
#define SCI_PULSE _delay_us(1); PORTD |= SCI; _delay_us(1); PORTD &= ~SCI;
uint8_t hv_cmd(uint8_t *dptr, uint8_t cnt) {
// data format is like write 0_DDDD_DDDD_00
// read D_DDDD_DDDx_xx
uint8_t sdo=0x00;
while (cnt) {
uint8_t sdi = *dptr++;
uint8_t sii = *dptr++;
uint8_t cmp=0x80;
sdo = 0x00;
PORTD &= ~(SDI|SII);
SCI_PULSE;
//sdo = ((PINB&SDO) ? 1 : 0);
//sdo = ((PINB&SDO) ? 0 : 1);
// 0x1e92 06
// 0x62df b0110 0010 1101 1111
while (cmp) {
sdo <<= 1;
//sdo |= ((PINB&SDO) ? 0 : 1);
//sdo |= ((PINB&SDO) ? 1 : 0);
if (PINB&SDO) sdo |= 0x01;
if (cmp&sdi) PORTD |= SDI;
//else PORTD &= ~SDI;
if (cmp&sii) PORTD |= SII;
//else PORTD &= ~SII;
SCI_PULSE;
//sdo |= (PINB&SDO) ? 1 : 0;
cmp >>= 1;
}//while
SCI_PULSE;
SCI_PULSE;
_delay_us(100);
cnt--;
}//while
//sdo = cnt;
return sdo;
uint8_t chip_sig[] = { 0xee, 0xee, 0xee, 0xee, 0x00, 0x00 };
void read_chip(uint8_t release_reset) {
cli();
busy++;
// enter hv mode, everything go low
DDRB |= (VCC|HIV|SDO);
PORTB &= ~(VCC|SDO);// Vcc and data out off
PORTB |= HIV; // 12v off
DDRD |= (SCI|SDI|SII);
PORTD &= ~(SCI|SDI|SII);
//_delay_ms(50);
PORTB |= VCC; // Vcc on
_delay_us(40);
PORTB &= ~HIV; // turn on 12v
_delay_us(15);
DDRB &= ~SDO; // release SDO
_delay_us(300);
// should be ready to issue commands
// read signature
// default fuse settting taken from http://www.engbedded.com/fusecalc/
// mcu - id - factory fuse low-high-extended
// t13 - 1e9007 (07) - 6a-ff
// t25 - 1e9108 (18) - 62-df-ff
// t45 - 1e9206 (26) - 62-df-ff
// t85 - 1e930b (3b) - 62-df-ff
// t24 - 1e910b (1b) - 62-df-ff
// t44 - 1e9207 (27) - 6a-df-ff
// t84 - 1e930c (3c) - 6a-df-ff
// signature { 0x08, 0x4c, 0xpp, 0x0c, 0x00, 0x68, 0x00, 0x6c
// write fuse { 0x40, 0x4c, val, 0x2c, 0x00, 0x64/0x74, 0x00, 0x6c/0x7c
// read fuse { 0x04, 0x4c, 0x00, 0x68/0x7a, 0x00, 0x6c/0x7c
uint8_t cmd[] = { 0x08, 0x4c, 0x00, 0x0c, 0x00, 0x68, 0x00, 0x6c, };
uint8_t *pdata = chip_sig;
uint8_t i;
//____________________ read device signature
for (i=0;i<3;i++) {
cmd[2] = i;
if (i)
*pdata++ = hv_cmd(&cmd[2], 3);
else
*pdata++ = hv_cmd(cmd, 4);
}//for
uint8_t id[] = { 0x07, 0x18, 0x26, 0x3b, 0x1b, 0x27, 0x3c, };
uint8_t mcu[] = { 0x13, 0x25, 0x45, 0x85, 0x24, 0x44, 0x84, };
if ((chip_sig[0] == 0x1e) && ((chip_sig[1]&0xf0) == 0x90) &&
!(chip_sig[2]&0xf0)) {
chip_sig[1] <<= 4;
chip_sig[1] |= chip_sig[2];
switch (chip_sig[1]) {
case 0x07: chip_sig[1] = 0x13; break;
case 0x18: chip_sig[1] = 0x25; break;
case 0x26: chip_sig[1] = 0x45; break;
case 0x3b: chip_sig[1] = 0x85; break;
case 0x1b: chip_sig[1] = 0x24; break;
case 0x27: chip_sig[1] = 0x44; break;
case 0x3c: chip_sig[1] = 0x84; break;
default: chip_sig[1] = 0xee; break;
}//switch
chip_sig[0] = 0x00;
for (i=0;i<7;i++) {
if (chip_sig[1] == id[i]) {
chip_sig[0] = i;
chip_sig[1] = mcu[i];
}//if
}//for
pdata--;
}//if
//____________________ reset fuse
if (release_reset) {
cmd[0] = 0x40;
//________________ write fuse low bits
cmd[3] = 0x2c; cmd[5] = 0x64;
if (chip_sig[1] == 0x13 || chip_sig[1] == 0x44 || chip_sig[1] == 0x84)
cmd[2] = 0x6a;
else
cmd[2] = 0x62;
hv_cmd(cmd, 4); _delay_ms(50);
//________________ write fuse high bits
cmd[5] = 0x74; cmd[7] = 0x7c;
if (chip_sig[1] == 0x13)
cmd[2] = 0xff;
else
cmd[2] = 0xdf;
//________________ write fuse extended bits
if (chip_sig[1] != 0x13) {
cmd[5] = 0x66; cmd[7] = 0x6e;
cmd[2] = 0x01;
}//if
}//if
//____________________ read fuse
cmd[0] = 0x04; cmd[2] = 0x00;
cmd[3] = 0x68; cmd[5] = 0x6c; // fuse low
*pdata++ = hv_cmd(cmd, 3);
cmd[3] = 0x7a; cmd[5] = 0x7c; // fuse high
cmd[3] = 0x6a; cmd[5] = 0x6e; // fuse extended
}//if
// done, turn things off
PORTB |= HIV;
busy--;
sei();
uint8_t menu=0, loc=0;
void main(void) {
TCCR0B |= 0x01;
TIMSK |= _BV(TOIE0);
TCNT0 = 0x00;
DDRA = PORTA = 0;
DDRD = PORTD = 0;
DDRB = (VCC|HIV|SDO);
//DDRB = (VCC|SDO);
PORTB = HIV; // 12v off
_delay_ms(50);
read_chip(0);
sei();
while (1) {
//_____________ "state" bits LBTSRZPP
// L - long hold, B - button, T - ticked, S - setup mode,
// R - refresh, Z - buzzer PP - digit edit position
//_____________ "menu" bits TxxOxMMM
// T - in toggle mode
// O - option used
// MMM - menu id (1-4)
if (state & ST_TICKED) {
state &= ~ST_TICKED;
}//if
if (state & ST_REFRESH) {
state &= ~ST_REFRESH;
dot = _BV(mode);
if (mode) {
seg2port(chip_sig[mode*2], 0x40);
}//if
else {
seg2port(POS__, 0);
seg2port(POS_t, 1);
}//else
seg2port(chip_sig[mode*2+1], 0x42);
}//if
//_____________________________________ check input
if (state & ST_BUTTON) { // needs attention
loc = 0;
if (state & ST_PRESSED) {
// normal pressed, rotate display mode
mode++;
if (mode >= 3) mode = 0;
}//if
else {
// pressed and held, reset fuse
mode = 0;
read_chip(1);
_delay_us(100);
read_chip(0);
}//else
state &= ~ST_BUTTON;
state |= ST_REFRESH;
}//if
}//while
Best Answer 7 years ago
CC to CA is a hardware issue, rather than a software one. What hardware have you got.
Answer 7 years ago
Steve, in these 2 lines of code. How do we read the 0x7e and the 0x30. Is there a chart to cross. What are those two that called?
#define LTR_0 0x7e
#define LTR_1 0x30
Answer 7 years ago
Do you mean what does 0x7E mean ?
Answer 7 years ago
Yes what does it mean, how to read it and what is it called, such as binary, char ect.
Answer 7 years ago
Its called "hexadecimal", and its a compact method of writing numbers for computing. It is a number in Base 16, so a digit counts as
0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F,G,H, - or 0000 to 1111 in binary.
Now here, an 8 bit number is composed of TWO hex digits. One "Nibble" (half a byte) represents a single hex digit, so any 8 bit number in binary can be split into to two hex digits.
0111 1111 = 7F
0011 0000 = 30
0011 0001 = 31
1111 1111 = FF
Does that help ?
Answer 7 years ago
Yes it does help and makes sense. Although the G and H through me for a bit as it seems it should stop at F.
So the 0x7e, the 7e part is 0111 1110. Not sure about the 0x part.
This is shorthand for binary.
Next thing.
In Arduino you would set the pin to an output, then set it high. What is the equivalent of that in my C/C++ example.
I recognize some addressing of a port DDRB, port B.
What is actually turning on or off say pin6 or pin4?
Answer 7 years ago
He he, you're right. NOT H !!
This is MUCH lower level programming than Arduino. I am not an Atmega specialist, you need to find the programming manual FOR THE CHIP to get to this new, much higher level of programming.
There is a port mode register which sets the properties of the pins on Atmega's.
Answer 7 years ago
DDR - Data Direction Register. That's the beastie that you need
http://www.slideshare.net/rbts11/avr-programming-basics
Answer 7 years ago
That is a great link. It is all cover exactly what i am asking about.
Thanks
Answer 7 years ago
Alright seems we have beet this on the rocks enough.
Thanks
Answer 7 years ago
Letter '0'
Answer 7 years ago
Its a 4 diget 7 seg display with 27 pins not 12. But i have multiplexed the 27 down to the standard 12.
In Arduino i am able to change CC TO CA or visa versa in the code. This code i am just not sure yet.
Answer 7 years ago
Driven by an ATtiny2313
