203Views5Replies
Author Options:
Changing brakes on an '06/'07ford freestar, how do we push the cylinder back in? Answered
We bent a cast iron pipe clamp trying to push the brake cylinder back in, it didn't budge.
The Ideanator
The Ideanator
Best Answer 11 years ago
As it turns out, the cylinders had to be compressed AND twisted to get them back in.
acidbass
acidbass
11 years ago
you need to use a hand crank lever that can push the piston back
NachoMahma
NachoMahma
11 years ago
.  Bleed all the pressure from the cylinder. Should be a "Zerk"-type fitting on the back of the cylinder or on the master cylinder.
.  Be sure to bleed air from entire system when finished replacing pads.
The Ideanator
The Ideanator
Answer 11 years ago
I know how to change brakes, we tried all of that already.
steveastrouk
steveastrouk
11 years ago
I've had problems where the cylinder was so crappy from corrosion that the piston WOULDN'T go back. I had to push the piston out, then remove the caliper, then clean the cylinders with a fine abrasive on a piece of dowel.
CLEAN the cylinders scrupulously to remove any contaminating grit before you reassemble.
