3435Views9Replies
Author Options:
Cheap casting compound? Answered
I´m on a budget and looking for a compound that can either be poured into a mould like plaster or is at least very soft and hardens in a short time without massive shrinking. (low temperature melting metals -> too heavy, plaster -> not rigid and hard enough, epoxy -> too expensive)
Tags:casting
just pick a name
just pick a name
10 years ago
I've never tried Ultracal, but Durabond 90 sets really hard, pretty much too hard to sand. It takes longer to set up, like overnight.
seandogue
seandogue
10 years ago
There's mortar mix. or Portland cement. if used pure, it would have a rough finish, but it's much harder than plaster and an 80lbs bag costs under $10
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Also Ultracal 30, a cement variant which takes excellent detail and cures extra hard. I used to use it to make molds for foam latex appliances, and it worked very well. It's pretty heavy, though. Wish we knew what the casts were going to be used for....
Fypsigon
Fypsigon
Answer 10 years ago
...ultracal seems to be a mixture of gypsum and cement, maybe i should experiment with it...
I want to use it for small structures so weight is not a problem, if it´s strong enough i could make them hollow....
RavingMadStudios
RavingMadStudios
Answer 10 years ago
If you're looking for something that works and takes detail like plaster, but is much much more durable, Ultracal might be just the thing.
seandogue
seandogue
Answer 10 years ago
Apparently low temp metals. I presume aluminum, gold, silver, lead, and or tin
Fypsigon
Fypsigon
Answer 10 years ago
....i´m already using Oogoo to make molds, fantastic idea btw....
