113Views6Replies
Author Options:
Choosing a relay? Answered
I was about to make a project, I was all set then I realized that I hadn't chosen a relay yet. (Circuit http://2.bp.blogspot.com/-IdzxyPF4WYE/UfBCWb0deoI/AAAAAAAADZs/1-eYB2ufQCA/s1600/Clap+Switch.jpg) As I didn't know anything about relays or AC voltage I started studying. At the end I came to this. As I will be controlling lamps with either incandescent bulbs or led bulbs and phone chargers a 5v, 220v 1a relay will be enough, since Bulb 0.27 A, LED 100 MiliAmps and Phone Charger a few watts. So the question is that are my calculations right and what else should I know about relays e.g operating voltage resistance and other stuff. Oh and is there a 0.5a relay and if there is will that be enough?
Thanks in advance.
-Prickly Potato
Downunder35m
Downunder35m
5 years ago
Since neither the price ,nor the function make any difference, better go for a 5 or 10A relay.
It is always better to go bigger here so the contact of the relais have a longer life ;)
SA-DIY
SA-DIY
Answer 5 years ago
Price is an issue.........since im funding this project myself. Is 2a relay good enough? Since ALL im gunna plug in is a lamp and phone charger (not at once)
Downunder35m
Downunder35m
Answer 5 years ago
Should be no problem though...
SA-DIY
SA-DIY
Answer 5 years ago
Ok thats settled now can you choose a fuse for me? 2a relay and i live in Pakistan. Oh and tell how to wire it ? :)
rickharris
rickharris
Answer 5 years ago
Google relays so you understand how they work and how to connect them.
Your relay may have a data sheet you can refer to.
3 amp fuse if you can get one. A fuse to be useful should in simple terms be as close to the load current as possible.
seandogue
seandogue
Answer 5 years ago
+1. Nothing we can say will beat what you can easily google.
Google "relay circuit images"
