148Views7Replies
Christmas lights question?
Is there anyway to set up 2 strands of christmas lights so that when one is on the other is off and then they switch every couple of seconds.?
Best Answer 9 years ago
Buy a low voltage relay that a 555 timer will switch (see 555 data sheet for max voltage, current.)
Build the 555 astable timer cct with a period of 2 seconds.
As the time turns the relay on and off so the relay triggers between the 2 light strings.
I am assuming the light are mains powered if they are low voltage - LEDs for example you could build an astable cct and drive them directly if you choose the transistors well.
Answer 9 years ago
I'm sorry I wasn't very specific. I'm wanting to do this with two strands of christmas lights. The kind that you plug into the wall not battery opperated so its not low voltage.
Answer 9 years ago
He means one that is contolled by low voltage but has 110 volt contacts.
Answer 9 years ago
Then go for the relay option. That's why I posted both approaches.
Answer 9 years ago
I understand now. I got it working. Thank you very much.
9 years ago
Here is a simple circuit with R1=1K, R2=29K, C=100uF and
the Diode a 1N4001 about 2 seconds each. . . . A
9 years ago
It can be done. You just need some kind of timer, or micro controller. Maybe get two timers, and sync their on/off periods?
