104Views4Replies
Author Options:
Circuit Help Needed Answered
Hello, i need help with a project for school due in 3 months. And i  need help with a circuit with some odd requests.
A variable resistor will change the voltage from 1-18v.
From voltages 1-10v will heat up a peltier tile  and from voltages 11-18v will change polarity around causing the peltier tile to then cool down but at a faster rate. This all needs to be done without a switch and only with the  variable voltage.
If 1-18v is not possible 1-12v may be even better.
So voltages 1-10v will heat up a peltier tile and from voltages 11-12v will change polarity around causing the peltier tile to then cool down but at a faster rate. And again without a switch and only with the variable voltage.
Thanks! -Jon-
mpilchfamily
mpilchfamily
6 years ago
Hint: Look at the LM317.
Though you may need to find another direction here. Using a variable voltage to control a peltier is rather pointless and inefficient. Why would you want to flip functionality of a peltier with a voltage anyway? Are these requirements set by you or the teacher?
steveastrouk
steveastrouk
Reply 6 years ago
How else do you do it ? Admittedly, you really want to control the current, but voltage works OK.
mpilchfamily
mpilchfamily
Reply 6 years ago
He wants one range of voltages to make one side cool. Then he wants a higher range of voltages to reverse the current to the peltier so the cool side heats up. A toggle switch to allow the 12V to flow in one direction or another is much easier then using a microcontroller to since the higher voltage range and allow 12V to flow in the reverse direction.
steveastrouk
steveastrouk
6 years ago
That makes it a SCHOOL PROJECT and is therefore supposed to be YOUR work, not ours. We'll help, but you have to make the first move, or you are a cheat, and will deserve/may be thrown out of school.
