102Views3Replies
Coding question
In this line of code the N and Y have single quotation marks around them, what do they do?
if (goodOne == 'N' && buttonPushed == 'Y')
Best Answer 8 years ago
As Jayefuu suggests, its asking if the values of goodOne is literally the character 'N' - not yes, not no, not true, not false, not 1, not zero, but the character N. If it is N, and buttonPushed is Y, then it will evaluate true, and the if statement will execute.
Answer 8 years ago
I would say this answer is closest to fitting in with this sketch.
Thanks
8 years ago
Thank You to all that took you time to respond.
It seams the answer is not cut and dry to this single quotation " command ".
Even when i research this on Google i get 4 different answers to 4 searches. So i think it depends on how, why and what also for the code. Beings how i did't provide the rest of the code the answers will be different.
8 years ago
Tells the compiler to evaluate it as a string, I think. Take the quotes out, try to compile it and then look at the error it gives you, that might give a better explanation.
