826Views4Replies
Author Options:
Coil gun projectiles? Answered
Will solid discs (think coin-sized) work as coil-gun ammunition?
Or is a hole in the centre absolutely required for the eddy-currents to flow?
agent harmsy
agent harmsy
9 years ago
It would probably go out of the barrel, but a disc isn't the most ideal projectile. Had a little experiment the other day walking down the stair shaft at uni, dropped a couple coins down the middle and watched. The coin flips and flops and generally doesn't hit the bottom. If you put some kind of spin on it then it'd be brilliant, but pointed cylinders fly the best, at least in my coilgun :D Good luck.
Kiteman
Kiteman
Answer 9 years ago
There's a design that fires discs edge-first, but the ammunition shown in the design is washer-like (ie, a hole in the centre). I had been hoping one could be made to fire coins at a target, as a charity money-raiser.
eneergcam
eneergcam
9 years ago
Pretty sure any metal conductor will work, but with a varied effect.
JamesRPatrick
JamesRPatrick
9 years ago
A solid projectile will work(most DIY projectiles are solid). However, I don't think that a coin would stay upright in a barrel. A bullet shape would work though.
I think electromagnetic accelerators(the ones that can fire non-ferrous projectiles) that use washers for ammunition use a slightly different principle than regular coilguns.
