100Views7Replies
Author Options:
Coilgun does not work with capacitor? Answered
I have a coil of 8 layers of 50 loops, so 400 loops. which has a resistance of 0,91 ohm.
To power this I use 3 450V 220μF in series charged to about 1000V and when I connect my coil it gives a small spark and the Iron projectile doesn't move.
I know the coil works because when I connected it to my welding transformer of 70V It did work.
what am I doing wrong?
iceng
iceng
3 years ago
stefl5 should also be aware that EL capacitors are slow to discharge in a
coilgun despite C x V x V / 2 potential energy, which is why the
welding transformer worked....
steveastrouk
steveastrouk
3 years ago
Also be aware that capacitors rarely share voltage across them evenly, without biasing resistors.
iceng
iceng
Answer 3 years ago
+2
Extremely topical.
Josehf Murchison
Josehf Murchison
Answer 3 years ago
A schematic would be nice.
Without a schematic we cant tell if there is resistors or even a diode on the transformer secondary.
I forgot to mention make sure the diode between the step up transformer and the capacitors is working.
Josehf Murchison
Josehf Murchison
3 years ago
Sounds like the capacitors are not charging to capacity, if they were fully charged you should get a big spark at 1000 volts.
Check your connections and make sure of the capacitors polarity you could have one connected in reverse.
Downunder35m
Downunder35m
3 years ago
Coilgun usually operate with power level above the 5kW range.
As Stevastrouk pointed out you only have enough energy available to give your projectile a slight tap.
Unless your projectile is the size of a sewing pin it simply can't overcome inertia.
steveastrouk
steveastrouk
3 years ago
You have 73uF of capacitance, holding only 36Joules.
