280Views2Replies
Author Options:
Connect Arduino UNO to a Laser with TCP/IP or RS232 protocol Answered
Hi everyone, I am trying to comunicate with a Laser via ethernet or RS232 but I realy don't find enough information in internet to make my sketch. For TCP/IP, I am using a ENC28J60.
CLK ---> D8
SO ---> D12
SCK --->D13
SI --->D11
CS --->D10
VCC --->3,3v
GND --->GND
You will find attached the manual for TCP/IP comunications that the laser company gave me.
Finaly for RS232, I tried to use the TTL-RS232 module (MAX3232) to comunicate but I was not able to make it works. (attached the manual for RS232 comunications that the laser company gave me.
RXD ---> RX 0
TXD ---> TX 1
VCC ---> 5v
GNS ---> GND
Please could somebody helps me with the code.
Thank you,
Jonathan
wa7npx
wa7npx
2 years ago
For RS232 you probably just need to swap the receive and transmit pins. RS232 protocol states that each device will have a transmit and receive pin. In order to "hear" a device the transmit needs to enter the receive pin of the other device and vice versa.
https://www.engineersgarage.com/articles/what-is-r...
For ethernet, if the laser has an RJ45 connector like the
ENC28J60 you will need to use a crossover network similar to what you would do with RS232. Transmit needs to enter the Receive pins. The difference here is that there are 4 wires to swap. See the discussion here:
https://www.iplocation.net/rj45-wiring
Good Luck!
