10239Views3Replies
Author Options:
Connect power inverter's AC output to my home AC power Answered
How can I connect a DC power inverter's AC output to my home AC power without a transfer switch so the inverter does not get damaged.  Connect it directly or with what ?
steveastrouk
steveastrouk
11 years ago
ONLY a grid connected inverter is suitable for this kind of connection, and they are designed to go OFF when the grid goes down, for the reasons Kelsey says. Once wrong move and people can DIE, since you can readily backfeed the line transformer.
kelseymh
kelseymh
11 years ago
No.  You cannot.  Look up "grid inverter" on Google.  You need to match voltage and phase, and you must be fully isolated so that, as noted by Re-design, you don't feed power to neighbors inside the last transformer circuit.
Re-design
Re-design
11 years ago
You can not connect it with out a transfer switch.
That would be a violation of the elect. code and very dangerous.
Think about what would happen if a line man turned off the power to hook up your neighbors line while your inverter was powering up the line.  He could get electrocuted and you would be the cause of it.
If you're going to do it please do it right.
