1352Views4Replies
Author Options:
Connecting 2 pairs (4 speakers) to one amp & being able to switch between the 2 pairs ? Answered
Hey guys,
I want to be able to have 2 pairs of speaks hooked up to my hi fi system although only use one pair at a time. I want to be able to switch between either of the 2 pairs & don't want to have to go behind the amp to keep re/dis - connecting the wires to interchange them. I need some sort of a box or a speaker terminal to switch them on the fly when i can. Is this possible? Does such a device exist?
I don't want to spend a lot of money, if i know what to buy i wouldn't mind making my self one...?? Any help thanks...
Thanks in advance..
biolethal
biolethal
9 years ago
A good, solid SPDT switch will do it. connect your amp to the middle (common) pole and your sets of speakers to the two sides. make sure you use a large enough switch, or you will lose power and therefore music quality. alternatively, you could use a relay.
Re-design
Re-design
9 years ago
I just noticed that both versions use a common ground where the ground of both channels of the amp are tied together. Some amps don't like that and the grounds of each channel should be kept separate. Check your amp.
