Yes I need to use them both I am beginner in this field I need to know how can I do the wiring and the code for doing that if there is a sample one thanks a lot fir the help
I figure you know how to connect them. As Jayefuu said they just plug one on top of the other. What your probably looking to know is how to use them both in a sketch. You'll need to look at each shield and see what pins they use. If either of them need to use the same i/o pins then you will have to do some hacking on one of them to make them use an unused i/o. Then you'll have to adjust the sketch accordingly so it knows where the new connection is at.
8 years ago
8 years ago
8 years ago
What exactly are you struggling with? They're shields, one plugs into the arduino, the other plugs in on top of that...
