247Views5Replies
Author Options:
Connecting together a rechargeable 1.2V battery to source current and a 9V battery only to boost voltage? Possible? Answered
Output should be within acceptable voltages of a 5V/1A regulator. What would the schematic look like?
MahavishnuMan
MahavishnuMan
11 years ago
I would recommend using a switching regulator on the 9V battery for increased efficiency (and longer battery life).  The linear variety burn off excess voltage as heat and effectively waste electricity.
As stated before, there really isn't a good way to use the 9V to boost the voltage of the rechargeable batteries.
Sandisk1duo
Sandisk1duo
Answer 11 years ago
better yet, a boost-buck regulator for the 1.2V
MahavishnuMan
MahavishnuMan
Answer 11 years ago
Possible, but given the current draw he would sap the batteries in no time.
cyberpageman
cyberpageman
11 years ago
 As steveastrouk says, "no."  Current flows from high voltage to low, so the battery would attempt to charge the 1.2V source.
If you have a 5V regulator, the 9V battery will work well with it, giving you an output of 5 v.
