839Views7Replies
Controlling 10 RGB LEDs with three pots(with out a microcontroller)?
hello i was just wondering if it was possible to wire 10 rgb leds together run all the red leads to one pot, the blue to another, and the green to the third, and have all of the leds colors controlled by turning the pots.
Any information would be helpful. I am intending to use this as lighting on my head board in my room. Id be using 5mm UltraBright RGB Tri-color LEDs
Thanks to all who reply.
Best Answer 10 years ago
Try three circuits like this. Its inefficient, at low brightnesses, because the 317 dissipates all the power the LEDs aren't using.
Answer 10 years ago
If im not mistaken, the link that frollard posted uses this same idea?
Answer 10 years ago
Well this is my work...its simpler than Frollard's link.
Answer 10 years ago
Far simpler :)
10 years ago
It IS possible, but its not very elegant and will require similar/more parts than just using a uC. The reason being that the leds need current. To maintain their voltage they need x amount of current to flow from the supply. To dim them, the pot has to dump a portion of that current as heat (they're not very good at dumping a lot of current). When the leds are nearly off, the pot is nearly burning up.
To get around this you use a pot to drive a curent limiting led driver. this instructable does exactly that. It's as simple as you will find.
Answer 10 years ago
Thank you very much for the reply, This is almost exactly what i was looking for.
10 years ago
if you are determined to avoid microcontrollers then a 555 pulse width controller may be a solution - ccts on line.
for an easy microcontroller solution look at http://www.picaxe.com
