129Views17Replies
Author Options:
Controlling a servo with a Micro-controller? Answered
So I decided to spend some time to make a "gimbal" in a very loose sense. Basically I was experimenting using a square wave oscillator to generate the correct PWM to have a servo rotate between 0 and 180 degrees when a tilt sensor is tripped. After some research multiple sites said having a 1ms pulse every 20ms would have it move to the 0 degree position. Great so I will make a oscillator pulses ~1ms on one side and 19ms on the other. However this does not seem to be working. I am curious if it is a fault in my math or if the tolerance on the parts I am using are just too wide to be any good. Here is a diagram of my set-up with the values a came up with. One spot that may be weak is that I just notice someone somewhere mentioned using 50Hz for the timing I just used that number when I calc my figures. Any feedback?
 Also a side note is that I have been able to move the servo in one direction only and by accident ( in fact it's what inspired this project) when C1 & C2 were 2.2nF and the R1 & R2 were 10k potentiometers that I turned until something happened. Now that I am trying on purpose no results.
Jayccob
Jayccob
4 years ago
Mistake in the title suppose to be "Without" a micro-controller.
iceng
iceng
Answer 4 years ago
A 555 is only an RC timer oscillator
rickharris
rickharris
4 years ago
This version gives you continious control from the 555
Jayccob
Jayccob
Answer 4 years ago
Never thought of using the 555 timer. I will give that a go and let you know how it turns out.
iceng
iceng
4 years ago
I have not tested this. Servos need 5 to 6 VDC.
Like your Flip Flop the 555 makes the waveform u seek.
Be sure to click on the pic to see the whole image.
Jayccob
Jayccob
Answer 4 years ago
It is easier to buy a tester or use a micro-controller, but that isn't the point to be honest. I am doing this to help with my electronic skills and for fun. I came across discussion of something similar for low budget projects, but nothing further because they just broke down and got a controller.
rickharris
rickharris
Answer 4 years ago
a servo needs 5 to 6 volts to drive it.
Jayccob
Jayccob
Answer 4 years ago
The image above says 1.5v but I am actually using 3v (two AA in series) and has been working, but for experimentation I can throw a 9v on it.
rickharris
rickharris
Answer 4 years ago
As in my diagram below I would ALWAYS use a seperate power supply for the servo fro the elcetronics, common the ground supply.
rickharris
rickharris
Answer 4 years ago
Image didn't transfer. Click on image for full size.
steveastrouk
steveastrouk
4 years ago
Signal polarity ? 1mSec high in 19 low, or 1ms low, 19 high ? It matters.
Jayccob
Jayccob
Answer 4 years ago
Yeah single palarity. And 1 mSec high and 19Sec low. These are some of the images I came across that may help explain the PWM pulse I am attempting.
steveastrouk
steveastrouk
Answer 4 years ago
Have you measured the timing ? Its pretty critical. If your signal is 1.1mSec, in 22, it won't like it. There are good reasons to digitally synthesise it.
Jayccob
Jayccob
Answer 4 years ago
Ok, I did a little experimenting with the design that I know can move the servo in one direction, and drew up the math so you can see it. In case you are unfamiliar with the equation. T= total time, t1= HIGH time of the left transistor, t2= HIGH time of the right transistor. All three of those values must be in Seconds. C1 and C2 are the capacitor values of their respective transistor, must be represented in Farads. Then R1 and R2 are the resistors for the capacitors in Ohms.
At this point I am wondering if reworking the values for microseconds may be the answer. Any thoughts?
Jayccob
Jayccob
Answer 4 years ago
The only thng I have been able to do it calculate the needed number, chose the closest values I have then re-calculate the numbers using those values. I have gotten it down to something like .00100188 Sec on one side and .0192924 sec on the other, but this doesn't take into account the 10% my resistors or Capacitor have. I unfortunately don't have a oscilloscope to measure it any better.
Jayccob
Jayccob
Answer 4 years ago
So to help clarify, the transistor on the left will be on for 1ms and the one on the right for 19ms back and forth. Because the control wire for the servo is only on the left transistor it should be getting power for that 1ms every 20ms created the hoped for effect.
