94Views8Replies
Author Options:
Converting sounds into motion without a microcontroller Answered
I want to build a circuit which converts 3 specific frequencies into a voltage, then to be used by 3 different servos, I don't need to use a microcontroller!! what should I use other than microphone, op amp, 555 timer, servo and comparator for this circuit?
Which one is better LM567 OR LM2907 to convert the frequencies?
Thank you in advance!! Waiting for your reply ASAP :)
Joe,)
steveastrouk
steveastrouk
4 years ago
The 567 has the selectivity you need. The rest should be pretty simple. 555 generating a 50Hz ramp etc.
joee1
joee1
Answer 4 years ago
Steve!! that's great to see your reply!! the 567 is it better than the 2907? because the frequencies might be in the same range!! how is it better?
steveastrouk
steveastrouk
Answer 4 years ago
The 567 is designed to be tuned to the frequency you want to pick up. Put three in for three frequencies. Otherwise, you need a three-way window comparator.
joee1
joee1
Answer 4 years ago
Steve!!!So, The 567 works for a signal coming from a microphone condensor? Also, How can I tune it? I am sorry for these questions!! but I am just a beginner. Thank you :)
steveastrouk
steveastrouk
Answer 4 years ago
Things "work" when you design them. Amplify the mic signal, pass it to three 567s. Adjust the RC networks around them to pick the frequencies of interest.
It really is simpler with a microcontroller, or make the frequencies of interest the same as those of standard phone DTMF signals.
joee1
joee1
Answer 4 years ago
thanks buddy!! :)
rickharris
rickharris
4 years ago
http://www.next.gr/circuits/Sound-To-Dancing-Light...
Your going to find this hard going without the microprocessor at least to control the servos
The above cct gives you 3 filters to seperate out high med and low frequencies. Although it gives an output to LEDs it will show you the principles involved.
joee1
joee1
Answer 4 years ago
thanks rick for your reply!!! but, I am trying to build this project without any microcontroller!!
