395Views5Replies
Author Options:
Corrupt word file - says to use text converter? Answered
Hello, I have been reading some posts about you to repair a file and it says to use the text converter.  I dont see how to use it though.   I want to repair this file.
Tags:Word
josephcols81
josephcols81
Best Answer 6 years ago
That's true as a Text Editor such as Notepad doesn't work with formatting, usually shows. Might try it in WordPad. I've had success opening stubborn files in QuickView Plus, usually can copy readable text and paste into a program.
Also look here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/word/919-office-documents-randomly-corrupting-possible-malware-issue
Or:
Word Repair Kit
An advanced Microsoft Word repair tool from Repair Kit that has been designed from ground up to match the skills and needs of the most inexperienced users looking to find out how to repair Word document data on their own. The program offers a sleek interface and full support of all Word document formats.
For more information: http://www.word.repair/
SamR128
SamR128
4 years ago
If you are getting a problem with opening a MS Word file, then you can also try Word Repair tool to successfully restore your all word document. It is much capable of restoring data such as paragraphs, headers, images, hyperlinks, footers, OLE objects, labels, tables, graphs from the corrupt Word document. Read more: http://www.repairwordfile.org
AlfredG6
AlfredG6
5 years ago
Use Word Repair utility repairs damaged or corrupt MS Word documents with ‘docx’ or ‘doc’ extensions. It can conduct safe and efficient recovery of Word files. It preserves original font, text, headers/footers, and images of documents. It can repair inaccessible documents and show all the characters unreadable. To download visit :-
http://www.mannatsoftware.com/stellar-phoenix-word-repair.html
alexsbutler
alexsbutler
5 years ago
Kernel
for Word Repair tool such a great solution for repair corrupted or
damaged MS Word file. With the help of this utility user can resolve
all MS Word file corruption issues and errors. It supports all
version of Windows operating systems like Windows 2000, 2003, XP,
Vista, 7,8 etc. For more information visit here : http://en.wordrepair.org
rickharris
rickharris
6 years ago
Usually word files that are corrupt have a bad header - the part that tells word about fonts, formatting etc.
If you open your file as a text file, you may be able to do that with word or try using note pad or word pad - these should be part of your windows system. You may need to change the .doc to .txt to open with notepad.
You will see the file and LOT or guff at the start and end but the text should be in there somewhere, you need to cut and paste it to an new document.
this is an example opened in wordpad.
The text says "this is a test document" I only copied the top half down to the text!
I opened it by right clicking the file and selecting open with.
