626Views7Replies
Author Options:
Cosine graph manipulation help. Answered
I am starting a electric vehicle project and have a math question which is relevant.
This may not be the best place to ask this question but here we go anyway.
Is there anyway to manipulate a Cosine graph so that the max and min points are the same and the period is the same while the x-intercept is different? (When compared to y = Cos x)
drknotter
drknotter
9 years ago
What you're describing is called a phase shift. Basically, if your original function is
cos(2*pi*t)
a phase shift would look something like
cos(2*pi*(t+delta))
wherer delta is the magnitude of the phase shift. Hope this helps.
NoNameCola
NoNameCola
Answer 9 years ago
I am looking for a manipulation in which both the max and min points stay in the same place as well as having the same period but one that changes the
x-intercept.
For example:
Points before manipulation:
0-pi
Max (0,1)
Min (pi, -1)
Period (2pi)
X-intercept (1/2pi)
After manipulation
0-pi
Max (0,1)
Min (pi,-1)
Period (2pi)
X-intercept (3/4pi)
kelseymh
kelseymh
Answer 9 years ago
You can't, not if you wan't a simple sinusoid. Your constraints are inconsistent, as you should be able to see. You might be able to construct a envelope function which matches your constraints, but that's not a "manipulation," it is a new function, defined either with piecewise segments and continuity conditions, or as an infinite sum of Fourier components.
NoNameCola
NoNameCola
Answer 9 years ago
Thanks that was all I wanted to know.
NoNameCola
NoNameCola
Answer 9 years ago
After
NoNameCola
NoNameCola
Answer 9 years ago
Here are some crude ms paint examples:
kelseymh
kelseymh
Answer 9 years ago
Why do you treat the phase shift as a fraction of 2pi? I'm used to it being written cos(wt + d) where w is the angular frequency = 2pi*f.
