392Views5Replies
Author Options:
Could a Pug Mill be used to make uniform Earth Bricks suitable for construction? Answered
I've been looking for ways to create Compressed Earth Bricks and thought about using a Pug Mill (commonly used to get air out of clay) with a rectangular extruder to do all the hard work.  Has anyone had experience with these mills?  Am I crazy for thinking this could speed up the process of building with earth?
steveastrouk
steveastrouk
8 years ago
I don't see how you would get the isostatic compression that making them individually would give you, so the resulting blocks would tend to fall apart.
Steve
kretzlord
kretzlord
Answer 8 years ago
I'm just going by my limited experience with pug mills. The extrusion that comes out of them is pretty darn solid (and yes, i understand a mix using sand would be less so). as far as the compression goes, i know these mills are used to remove all air from clay, giving the highest possible density with a given material.
If you could have an extrusion of say, 10'x8"x18", you could cut it into sections and let the blocks dry individually. This would turn the blocks into a batch process rather than a 1-off.
Thanks for the replies!
Kiteman
Kiteman
8 years ago
What is the normal method for making earth bricks?
Most earth-built houses I have seen recently have the earth in bags, or poured into hollow forms that stay in place when the house is built.
kretzlord
kretzlord
Answer 8 years ago
well, i had my terminology wrong, they are "Compressed Earth Blocks". the method involves having a slightly damp clay/sand/binder mixture that gets pressed in a form. the blocks are released from the form and set out to dry The blocks are made one at a time this way, though there are larger machines that automate the process. the result is similar to a rammed earth wall (but much smaller)
http://en.wikipedia.org/wiki/Compressed_earth_block
