896Views8Replies
Author Options:
Could i replace this 555 in this circuit with an arduino? Answered
http://www.aaroncake.net/circuits/flampdrv.gif
I
n this could i replace the 55 timer this with a arduino?
If so what would the code be? If not could you atleast tell me what kind of wave the 555 is producing so that i can emulate the same with an arduino?
The circuit in question is for a 12 VDC flourocent lamp driver
Thanks
steveastrouk
7 years ago
It'll be a fairly high frequency square wave. The code just needs the "timer" unit loaded, and you can drive a pin from that.
What a waste of a processor though......
qwerty156steveastrouk
Answer 7 years ago
So i downloaded the frequency timer.zip file from
http://www.arduino.cc/playground/Code/FrequencyTimer2.zip
Then i extracted it in arduino-0022/libraries but i still get this error
sketch_jul31a.cpp:1:29: error: FrequencyTimer2.h: No such file or directory
sketch_jul31a.cpp: In function 'void setup()':
sketch_jul31a:3: error: 'FrequencyTimer2' has not been declared
sketch_jul31a:4: error: 'FrequencyTimer2' has not been declared
steveastroukqwerty156
Answer 7 years ago
Two things:
1.) Where did you put the files, it should be in "libraries"
2.) Once it is, open the FrequencyTimer2.h file in wordPad or some other text editor.
At the top of the file there is a line
#include <wiring.h>
Comment it out like this:
//#include <wiring.h>
and add the line
#include <WProgram.h>
underneath it.
Steve
rickharris
7 years ago
I guess at a cost and with different connections AND you would need to be able to programme it in C++ AND it will be bigger than the 555 AND microprocessors are notorious for being upset by high frequency changing wave forms even when they generate them.
steveastroukrickharris
Answer 7 years ago
Well, unless the OPs more specific, there are about 5 lines of code needed to do this.
steveastrouksteveastrouk
Answer 7 years ago
#include <FrequencyTimer2.h>
void setup() {
pinMode(11,OUTPUT);
FrequencyTimer2::setPeriod(200);
FrequencyTimer2::enable();}
void loop ( ) {}
I lied. 6.
orksecurityrickharris
Answer 7 years ago
(well, in C...)
Can certainly be done. Will cost you more cash and more effort.
Of course if you have some reason for wanting to be able to vary the frequency programmatically, an Arduino might make sense.
