62Views1Replies
Author Options:
Countdown timer doesn't exit and the loop never repeats? Answered
We want to run the stepper motor by 180 degrees and want to repeat it after long delay (say 2 hours or so) with a countdown timer displayed in LCD attached to Arduino. Every thing happening successfully except the loop doesn't start after the countdown ends.
#include <Stepper.h>
#include <LiquidCrystal.h>
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int hours = 0; // start hours
int minutes = 0; //start min
int seconds = 10; //start seconds
int stepCount = 0;         // number of steps the motor has taken
void setup() {
  // initialize the serial port:
  Serial.begin(9600);
  pinMode(13, OUTPUT);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
void loop() {
  // set the cursor to column 0, line 0
  // (note: line 0 is the first row, since counting begins with 0):
  lcd.setCursor(0, 0);
  lcd.print("DRUM ROTAING");
  for (int i = 0; i <= 100; i++) {
    // step one step:
    myStepper.step(1);
    Serial.print("steps:");
    Serial.println(stepCount);
    stepCount++;
    delay(125);
  lcd.clear();
  lcd.begin(16, 2);
  lcd.print("Count Down Timer ");
  delay(150);
  while (hours > 0 || minutes > 0 || seconds >= 0) {
    lcd.setCursor(4, 2);
    (hours < 10) ? lcd.print("0") : NULL;
    lcd.print(hours);
    lcd.print(":");
    (minutes < 10) ? lcd.print("0") : NULL;
    lcd.print(minutes);
    lcd.print(":");
    (seconds < 10) ? lcd.print("0") : NULL;
    lcd.print(seconds);
    lcd.display();
    stepDown();
    delay(1000);
void stepDown() {
  if (seconds > 0) {
    seconds -= 1;
  } else {
    if (minutes > 0) {
      seconds = 59;
      minutes -= 1;
    } else {
      if (hours > 0) {
        seconds = 59;
        minutes = 59;
        hours -= 1;
      } else {
We used break, return 0, continue, etc. but somehow didn't work. Kindly tell how to exit so that program repeats itself. Thanks.
steveastrouk
steveastrouk
4 years ago
Put everything you want in the infinite loop in an infinite loop, like while (1=1) or
while (TRUE)
