113Views4Replies
Create a project template pdf file
Hello, please how do I create a scale pdf file of a template drawing I did on paper for my project so that viewers can download and print out the correct sized template?
1 year ago
Use a PDF printer driver and print your drawing to scale ;)
To make confirmation easy add a fixed lenght line.
I usually do a 10cm one.
Reply 11 months ago
Thanks for the tip. I really appreciate it😊
Best Answer 12 months ago
https://www.ilovepdf.com/jpg_to_pdf lets you choose: "Same size as image". Best if you also choose "No margin"
Now the question changes: How can i define how big my image is?
Answer: In your Grafics-Program (If you dont have any good, download and install the Free PaintDotNet which is more than you ever need honestly) you can directly tell how big your image will be in inches or cm. You get there thru "image" --> "Size" or simply CRTL-R.
See attachment
See, the size of an image is determined by 2 factors:
Pixel per length (in or cm) and Pixels in each axis. Paint.NET helps you out there very easy.
Have fun
Answer 11 months ago
Thank you for the help. I just used a scanner to scan the initial technical drawing I made and then converted the image into PDF. It worked
