2225Views7Replies
Author Options:
Current Draw for 178 RED LED's @ 20ma each. Is this really going to require 12vdc 3560ma power supply? Answered
Want to be sure before I purchase AC/DC Wall Wart. I was thinking a 1000ma supply would be ok. I'm I wrong on that or I'm I missing something.
Tags:LED
keydogstony
keydogstony
11 years ago
I guess we were all wrong. I completed the project with 177 LED's and it actually works with a 9 v battery. Not sure how long but it work for the few minutes I hooked it up. Wire 5 LED's in series with 68 ohm resister for each segment and then wired them all in parallel. I hooked up the 9v battery just to see what would happen. They all lit up bright. I may add more about this later.
keydogstony
keydogstony
Answer 11 years ago
Making a sign. The real intention was to put into my Truck and run off battery. A 4 amp 12vdc supply would be pricy as well. It needs to be bright. :) But would also like to use with a Wall Wart for inside use as well. I don't guess a LED Driver would help? Any idea?
kelseymh
kelseymh
Answer 11 years ago
If you're running off your truck battery, you've got 12VDC at "infinite" amps already :-) Make sure you put a 4A fuse inline with the sign, just in case.
AndyGadget
AndyGadget
Answer 11 years ago
If you're looking at having all LEDs on at once rather than individually controllable (which would be a wiring nightmare), you might be able to do something with these flexible LED strips. The ones I looked at draw 100mA for a 15 strip, so total would be a bit over an amp. They're meant for auto use so should be bright enough.
keydogstony
keydogstony
Answer 11 years ago
Well, I did find on eBay some 4amp 12vdc supplies for around $12.50. Not too bad. LapTop Supplies. But something less expensive would be better.
kelseymh
kelseymh
11 years ago
Yes. Current adds linearly, and your calculator has told the truth: 178×20 = 3560 = 3.56 amps. You will need a 4A rated power supply. Or, as AndyGadget suggested, get yourself low-current LEDs instead.
