164Views8Replies
Author Options:
DC to DC Convertor? Answered
Does anybody have a circuit that is able to turn solar power from a solar panel (preferably 1 watt) to make enough juice to recharge an iPad?
The iPad requires 10 watts of power to charge.
I wanted too use Adafruit's mintyboost but I don't think that has enough power to charge the iPad.
Any suggestions?
steveastrouk
steveastrouk
9 years ago
If you want 10W from the charger, you need slightly more than 10W from the panel - nothing you can do can create more energy than you put in. All you could do is use a 1W panel to charge a battery, so that IT can be used to charge the Ipad - but if you need 10W for 1 hour to charge the Ipad, you'll need 12-14 hours of charging to get enough energy in the battery to do the job
Steve
blinkyblinky
blinkyblinky
Answer 9 years ago
What if I have an 18 volt panel?
steveastrouk
steveastrouk
Answer 9 years ago
Can it deliver 10Watts ?
steveastrouk
steveastrouk
Answer 9 years ago
10 W under full sun conditions - what's actually practical ? Usually less than half that on average (in the UK, its a LOT worse than that !)
frollard
frollard
Answer 9 years ago
I'm pretty sure the ipad is one of those annoying ones that won't even accept the power if it's not available to flow at 10w...it just won't accept a trickle charge.
blinkyblinky
blinkyblinky
9 years ago
I need a cheaper solution than a 12 watt panel.
CameronSS
CameronSS
9 years ago
If you need 10 watts, you need 10 watts, and 1W isn't going to do it.
A DC-DC converter changes DC voltage. You can increase voltage with a corresponding drop in available amperage, or decrease voltage with the opposite effect, but watts are power, volts times amps. Watts into a DC-DC mostly equal watts out, ignoring the efficiency loss.
In other words, you need to add power. If you need 10W to charge an iPad, you need a 10W (or greater) supply. Get a 10W solar panel, hook up ten 1W solar panels, hook it up to a bicycle generator, but you can't increase power with a just a circuit.
