4833Views4Replies
Author Options:
DIY, AC to DC Converter, Variable 0-60vDC, variable 0-10A : is this possible and done with shoestring budget? Answered
Hey,
I've been experimenting with Electrolysis and have reached the end of what I can do with a couple of car batteries and a car battery charger.
I would like to build a AC to DC converter (as I can't find anything built with the options I want).
I believe the sweet spot I am headed for is 52 Volts and 1.5 -3 Amps.
I would like to have variable voltage output from 0-60 Volts and variable Amperage output of 0-10 Amps.
Is this something than can be put together on a hobbyist's budget?
Thanks In advance!
Re-design
Re-design
8 years ago
You need to find a big 120 volt to 60 volt step down transformer. Add a dimmer switch to the 120 side and a rect. bridge to the 60 volt side.  Now you have a 0 to 60 volt dc power supply.
Or,
Find a powerstat or variable transfomer (lots on Ebay) and add a rect. bridge to that.
But be aware the either one of them has the power to KILL you or anyone who may touch the wrong thing.
steveastrouk
steveastrouk
Answer 8 years ago
The second option is lethal. They are not mains isolated !!
The first method is safe(r)
Steve
Re-design
Re-design
Answer 8 years ago
He could add an isolation transformer to the second one but that would just add more money. but it would be safer.
steveastrouk
steveastrouk
Answer 8 years ago
Phase control's the way to go, but transformers not rated for it will typically give half or less of the rated VA.
Steve
