1082Views12Replies
DIY phone headset to computer plug??
I would like to make one of these.
http://www.amazon.com/TOP%C2%AE-Headset-RJ9-RJ10-Adapter/dp/B00CXTO2NM
It is to connect to the headset port in my phone to record some greeting that I saved on my computer
It only needs to connect the computer speaker to the phones mic.
I need to know the pinouts of both connectors and what to connect together
Thanks
Best Answer 5 years ago
The audio is on your computer, and you want to put it on your phone system, correct?
Answer 5 years ago
Yes but i cant just transfer it it needs to be recorded through the head/handset.
Answer 5 years ago
Ok I get it. So there's some links attached and all your need to do is wire the the left and right stereo wires to wire 4 of your RJ9 and the ground of your stereo to the wire 1 (stereo is your computer speaker output)
Stereo pinout: http://pinoutsguide.com/Home/Tele35s_pinout.shtml
RJ9 pinout: https://en.wikipedia.org/wiki/Modular_connector#4P4C
I hope this helps! :)
Answer 5 years ago
Thanks that is exactly what i was looking for
5 years ago
hold the phone up to the speaker and be done with it.
Answer 5 years ago
I did that, but it was hollow and you could not understand it
Answer 5 years ago
Keep in mind the clarity of the phone's mic is not vary good to start with. Likewise any answering machine or service will also have poor recording quality. So if you have a lot going on in the message then it will be distorted and you won't be able to understand it. Ever notice how bad hold music sounds. They are using a direct connection there as well. The phone system was never designed for even decent quality audio. Your recording may be beyond the ability of the phone system to adiqquatly use.
Answer 5 years ago
ok I will keep that in mind. It will at least improve it a little. But do i just connect the computer speaker to the phone mic as seen in this picture?
https://robert.accettura.com/wp-content/uploads/2010/09/20100912_4p4c_pinning.png
Answer 5 years ago
Yes that can work. But i wouldn't expect much improvement.
Answer 5 years ago
Yeah, Simplest Solution
when you talk your mouth is a inch or two away from the phone anyway right?
5 years ago
I have no idea what you're trying to do, but for looking up the pinouts for your devices, whatever they might be, I suggest pinouts.ru
http://pinouts.ru/
Answer 5 years ago
So i can just connect the computer plug to the phone plug?
