235Views6Replies
Author Options:
Data updating on thingspeak (cloude) only once Answered
 I am trying to update Thingspeak using Edison. It updates thingspeak but only at once.
If I have to update again I have to run the code again.
#include <WiFi.h>
#include <SPI.h>
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";  //TS
String writeAPIKey = "**************";    //TS
const int updateThingSpeakInterval = 20 * 1000;      // Time interval in milliseconds to update ThingSpeak (number of seconds * 1000 = interval)
char ssid[] = "*********";     //  your network SSID (name)
char pass[] = "*********";  // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
// initialize the library instance:
WiFiClient client;
String stringVal = "";
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
int failedCounter = 0;
int a;
float tempC;
int B=3975;
float resistance;
void setup() {
  //Initialize serial and wait for port to open:
  Serial.begin(115200);
   while (!Serial) {
//  check for the presence of the shield:
// if (WiFi.status() == WL_NO_SHIELD) {
  //   Serial.println("WiFi shield not present");
    // don't continue:
    //while(true);
// attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.println("You're connected to the network");
  // printCurrentNet();
  // printWifiData();
  void loop() {
a = analogRead(0);
resistance=(float)(1023-a)*10000/a;
tempC=1/(log(resistance/10000)/B+1/298.15)-273.15;
// converts temp  to string
stringVal += String(int(tempC))+ "."+String(getDecimal(tempC));
//char buf[16];
//String strTemp = floatToString(16 , cel , 5);
//Serial.println(strTemp);
// Print Update Response to Serial Monitor
  while (client.available())
    char c = client.read();
    Serial.print(c);
  // Disconnect from ThingSpeak
  if (!client.connected() && lastConnected )
    Serial.println("...disconnected");
    Serial.println();
    client.stop();
  // Update ThingSpeak
  if(client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval))
    updateThingSpeak("field1="+stringVal);
     Serial.print( stringVal);
     Serial.println("C");
     delay(1000);
     Serial.println();
  lastConnected = client.connected();
//function to extract decimal part of float
long getDecimal(float val)
int intPart = int(val);
long decPart = 100*(val-intPart); //I am multiplying by 100 assuming that the foat values will have a maximum of 3 decimal places
                                   //Change to match the number of decimal places you need
if(decPart>0)return(decPart);           //return the decimal part of float number if it is available
else if(decPart<0)return((-1)*decPart); //if negative, multiply by -1
else if(decPart=0)return(00);           //return 0 if decimal part of float number is not available
void updateThingSpeak(String  stringVal)
  if (client.connect(thingSpeakAddress, 80))
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: "+writeAPIKey+"\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print( stringVal.length());
    client.print("\n\n");
    client.print( stringVal);
    lastConnectionTime = millis();
    if (client.connected())
      Serial.println("Connecting to ThingSpeak...");
      Serial.println();
      failedCounter = 0;
    else
      failedCounter++;
      Serial.println("Connection to ThingSpeak failed ("+String(failedCounter, DEC)+")");
      Serial.println();
  else
    failedCounter++;
    Serial.println("Connection to ThingSpeak Failed ("+String(failedCounter, DEC)+")");
    Serial.println();
after running this code I get this(image attached)
iceng
iceng
4 years ago
I don't have time to block diagram your code but you should... Then modify the part
Serial.println();
client.stop();
and see if it remains connected.
Another approach I have mentioned. Use the block diagram and some new code that waits for a data change then at change log on send, log off and wait for another change...
iceng
iceng
4 years ago
So your code has a disconnect from ThingSpeak why?
I would make code that would update every time your data changed.
If every one was logged on sending null characters. ThingzSpeak would over load.
ANINDYAB5
ANINDYAB5
Answer 4 years ago
So what should I do now? Have you given me that code or given me a suggestion that on which part of my coding should be changed?
iceng
iceng
4 years ago
And your chief complaint question is ?
ANINDYAB5
ANINDYAB5
Answer 4 years ago
How shall I send the data continuously in Thingspeak
