46902Views11Replies
Author Options:
Dell Inspiron 1525 Internal Webcam not responding/broken, Help? Answered
The Webcam on my Dell Inspiron 1525 recently stopped working for no apparent reason, no changes were made to settings or hardware. It keeps telling me that no webcam is plugged it, and that I should attach one, The webcam is internal, and has had no previous problems. Any ideas on a fix?
RelaxedSoup
RelaxedSoup
Best Answer 11 years ago
Check the Dell site for webcam drivers and reinstall them, see if that fixes it. Here's the driver download page http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R165116&SystemID=INS_PNT_PM_1525&servicetag=&os=WLH&osl=en&deviceid=15135&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=222145, I don't know if you run XP or Vista, so you'll want to make sure you get the right drivers for your OS, the one I linked you to is the driver for Vista. Here's the main page http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=EN, the webcam driver is under Input Device Drivers. If the old driver is still on your machine, you should probably uninstall it before installing the new driver.
cosgrove
cosgrove
Answer 11 years ago
I'm running Vista 32bit Premium, I'm currently download the drivers and will let you know what the results are, Thanks for the Advice!
cosgrove
cosgrove
Answer 11 years ago
No such luck, Still trying to fix this problem, any Ideas? Is it possible that the webcam has just "burnt out"?
RelaxedSoup
RelaxedSoup
Answer 11 years ago
It's possible. You can look in the Device Manager and see if it shows up, if it's not there then there's a good chance it's fried. Go to Control Panel > Hardware and Sound > Device Manager. Browse around, I wish I could tell you where it should be listed, but I don't currently have a web cam. If it's fried, you could try and replace it yourself, or send it in, provided your laptop is still under warranty.
nrahoria
nrahoria
7 years ago
here is solution related to dell webcam and dell webcam manager
http://youtu.be/YFY59F36RhQ
nrahoria
nrahoria
7 years ago
here is the solution related to dell webcam. this will surely help you.
paladindeoro
paladindeoro
9 years ago
Hi, I tried to put the cam to work again.
I found this link and now its working in windows vista 32 bits
http://devid.info/download/44707/16
the driver from dell doesn't work.
Good Luck.
aotilia
aotilia
9 years ago
Hi!I the same problem but in my case I never activated the web before and when I tried to follow the steps bmxlife suggested, I got to a dead point because I couldn't fin any imaging devices.My search stopped at device managers and there is nothing there related to video drivers or webcam.It's as if my web didn't even exist on my laptop Help someone,please.
bmxlife757
bmxlife757
10 years ago
I have a dell inspiron 1525 as well and mine just went out the other day like you said for no reason. i was using it for skype and the next day it gave me the message "failed to connect please reconnect webcam". I went to (control panel>hard drive and sound>device manager) under device manager on my laptop the 8th slot down says Imaging Devices and if you click the box to the side it should drop down and ahould say "Laptop Integrated Webcam" if you double click that a bow should come up and there should be 3 tabs in the top left corner. If you click driver it will give you the options of "Driver Details, Update Driver, Disable, Uninstall" if you click disable and then click okay then it will change to enable. Click enable and click okay at the bottom of the window. It willthen ask if you would like to restart the computer. Restart it and the webcam should be working when it turns back on. Sorry this is so long but it worked for me hopefully it works for you
mothwoman
mothwoman
Answer 10 years ago
Oh, thank you thank you, I love you!!!  This works!!!!
nate79dawg
nate79dawg
11 years ago
make sure the webcam is turned on in the bios. if you did i bios update at any point it may have been turned off, or if you the bios was reset might be another reason
