94Views2Replies
Author Options:
Different types of motors on the same arduino? Answered
So I am still learning Arduino but I've already built quite a few robots. I'm stepping things up a notch by building a robot with several motors. I am using 9g servos, stepper motors, standard servos, and regular dc motors with l293d ic. I am also using 2 ultrasonic distance sensors. There will be 14 motors in all but I think Arduino Uno can only handle 12? I will be using an Arduino Mega, so will that be ok? I also want to know if you can put all these different motor types on the same Arduino and if it is possible, would writing a code be really complex?
iceng
iceng
3 years ago
Compared to all the equipment the robot needs to operate, the cost of a second Arduino is negligible.. Use the second uP to run a group of motors under direction of the primary Arduino and make up your own easy to decode serial commands to issue motion on the slave Arduino, like ; A1= motor-A-fwd-run , A0=motor-A-stop
and B2=motor-B-rev-run
or D27=servo-D-position-@-position-27`
also handy R14=status-motor14
and RR=status-motors running
You get the idea then the Primary Arduino is not tasked with time consuming details !
seandogue
seandogue
Answer 3 years ago
+1
no matter the embedded platform, once one has gone beyond the simple, using satellite controllers makes sense. It helps to isolate electronics, and it helps to organize management from a central governor.
rickharris
rickharris
Answer 3 years ago
+1
It's one of th things I really like about the Picaxe system (besided easy programming) they actually do an 8 pin chip that is quite powerful and cheap so you can easily build distribute systems - I2I support on them as well.
