76Views2Replies
Author Options:
Do I have to sand water clear casting resin? Answered
I'm a COMPLETE novice when it comes to resin of any kind. But I'd like to start doing my own flower castings as a hobbie. I was thinking of buying water clear casting resin- I want to be able to see the detail in the pieces but recently after watching a few videos and researching, i've found that I have to go through a sanding process. I thought that if I buy water clear then I wouldn't have to sand it because you will see the details? am I wrong in thinking this. Also,  if I cast items in glass jars will they come out super clear?
rickharris
rickharris
2 years ago
Use a silicone mold. The end surface will be as good as the surface of the mold.
PS Flowers MUST br totally dry to cast effectivly.
iceng
iceng
2 years ago
Only sand if the mold cavity is rough and not perfectly flat.. I use tight saran wrap or inside if an egg shell with slow cure rate, pull a vacuum and slowly let air back in to collapse any bubbles..
