513Views6Replies
Do Resistors work the same on AC voltage??
This isn't for a project but I'm interested if resistors still work the same: Wattage, Resistance...
5 years ago
Give a best answer Ac or Dc a resistor inhibits current combined with other elements it can do different things but that is all it does, other than a voltage divider.
5 years ago
There are a group of Power Resistors that are wire-wound and will exhibit inductance when used on AC unless they are specially wound like Dale NH wire-wound power resistors which are mostly not inductive at the lower AC frequencies.
5 years ago
The formulas are the same. Basically you can just substitute RMS values for {voltage, current, power} in place of values for constant or instantaneous
{voltage, current, power}.
Supposing Ohm's law, for DC, is
V = R*I
and P = V*I = R*I^2 = V^2/R
where V, I, P, are constant in time, or constant over an arbitrarily small interval in time (i.e instantaneous).
Substitute in RMS values, and it turns out, these equations are still valid,
Vrms = R*Irms
and Prms = Vrms*Irms = R*Irms^2 = Vrms^2/R
It's the same formulas, but the meaning is a little different, since now we're talking about RMS values, instead of constant or instantaneous ones.
5 years ago
Yes.
5 years ago
Yes. Assuming a standard carbon or composite resistor and low frequency AC. There will be minor issues and they can be worked around by working the AC as a RMS (root mean squared) value.
A resistor dissipates power as heat and it will do that just as well for AC as DC.
Things get funny at high frequency but that is more the nature of high frequency signals rather than the resistor.
Answer 5 years ago
http://www.electronics-tutorials.ws/resistor/res_8...
offers a good detaled explaination.
