3045Views5Replies
Author Options:
Do cheap pH meters work? Answered
I have seen $10-20 pH meters for testing soil in garden stores, home improvement/hardware stores. I was wondering do these give accurate readings? I am looking for a cheap and accurate way to test pH. Any suggestions even for other ph testing methods are appreciated. Thanks!
GardenMyths
GardenMyths
5 years ago
The cheap garden type meters or kits for $20 are not of much use. For a more in depth discussion visit
http://www.gardenmyths.com/soil-ph-testers-accurate/#more-1070
ClareBS
ClareBS
6 years ago
I've tried three ranging from $10 to $20 and none of them even budge even when I follow the instructions to the letter and put the tips in white vinegar.
lemonie
lemonie
9 years ago
I found an expensive one which looks good, but what you're really asking is "how accurate?"
I'd say "not very", if you want high-accuracy you'll need to spend much more.
L
AndyGadget
AndyGadget
9 years ago
Guessing a bit here, but I would think that the cheap soil pH meters work by measuring the conductivity of the soil rather than the pH. The conductivity will be higher with a lower pH i.e. more acid.
If it's soil you're testing, you may be better off with a litmus based test kit such as THIS which also tests for nitrogen, potassium and phosphorus which are instrumental to plant growth.
NachoMahma
NachoMahma
9 years ago
.  How accurate is accurate enough? What range are you measuring? What kinds of chemicals are involved?
.  Most of the cheapies I've seen worked well for their intended use, but definitely are not "laboratory grade" units.
