4478Views5Replies
Do you always need a buckpuck for high powered LEDs?
I want to power a Cree MC-E LED with a 12 volt 5 amp/h SLA battery. Most of the time you have to use a buckpuck (an LED Driver). Do you always have to use a buckpuck? If I have a 12 volt battery and a 12 volt LED like the CREE MC-E, then I don't need a driver, right?
Thanks
Jacob
Best Answer 10 years ago
For a high powered LED (or series of LEDs) you're going to want a constant-current regulator of some kind. The reason this regulator is needed is because without a current regulator, the LED will tend to draw too much current, and thus too much power (the product of voltage and current), and thus burn itself out.
The quote below is from here:
http://en.wikipedia.org/wiki/Light-emitting_diode#Power_sources
The parts in bold are words I think deserve emphasis.
Answer 10 years ago
+1. damn things are expensive and will burn up very easily.
10 years ago
Its never a great idea to rely on that. Steve
Answer 10 years ago
What do you mean? Don't rely on a circuit without a buckpuck?
Answer 10 years ago
The Crees need so much current conventional linear regulators won't hack it. You don't need to run a "Buck puck", but you DO need a switching current controlled regulator, as Jack points out exactly why.
