544Views12Replies
Author Options:
Do you think it is possible to make a homemade kite big enough to be able to lift you of the ground.? Answered
blkhawk
Best Answer 8 years ago
If you read and investigate a little more you could answer that question yourself. Because gliders have been around for over a century. Someone that, experimented with many gliders, was a pioneer Otto Lilienthal.
Kiteman
8 years ago
Yes.
For straight lifting, I would recommend a Cody or Bell tetrahedral system for a home-built lift.
Please be aware that kite lines on large kites can easily cut to the bone, and the first deaths in the aircraft industry were of kite-flyers being dropped from the sky.
amelaboyKiteman
Answer 8 years ago
Thanks for the warning. Ha ha. Forgot about that. Also, I was wondering if there was way to build something like this. Thanks
oldmanbeefjerky
8 years ago
yes,
ever heard of kiteboarding?
if you jump off the ground and pull hard on the kite it will lift you off the ground and so long as you dont slow down, or lower your leggs (same rules as on a swing), youll keep going up until your above the draft .
its the funnest thing ever
lemonie
8 years ago
Yes
The MadScientist
8 years ago
Of course it is. It would need to be at least 10 meters wide and have some method of getting it up there running with it won't do, maybe some kind of a cannon.
Re-design
8 years ago
Sure, but once you get off the ground you will have no control. Picture yourself bouncing off the neighbors houses.
R.A.T.M
8 years ago
well what matrials do you have and if you have some of the right ones yes
