99Views10Replies
Author Options:
Does Chromesteel disolve during copper-electrlysis with Coppersulfate? Answered
Hi
I want to refine some copper and change it to copper-dust-particles by means of copper-electrolsis in a bath of disolved coppersulfate.
Since my copper is in smaller bits id like to have some sort of etallic basket to hold the scraps.
I think i would like to go with a chromesteel-mesh i connect to the power. The mesh/basket contains my scrap-copper and the anode-sludge can pass thru the basket...
The basket (anode) and the copper-cathode are connected to the powersupply.
Now my question: I think the chromesteel shouldnt get disolved as long as i dont crank up the voltage too high or let it run without sacrificial copper at the cathode. If i would do that, it would start to split the water used in the solution and produce H and O. Bad. Also would slowly eat away the metals too. Bad^2
But as long as i have copper to be disolved at the cathode, it shouldnt do anything to my chrome-steel-basket, right?
Thanks for inputs from someone who knows it better than i do :)
Kiteman
Kiteman
6 years ago
Why not wire it the other way around? Put the impure copper inside the basket, let the pure stuff build up inside the basket:
Orngrimm
Orngrimm
Reply 6 years ago
Goood idea, but since i want to harvest the copper-dust a basket is not the best cathode... Too difficult to get it all out...
Also: Dont i need copper as inital-metal as cathode? Would copper deposit on steel?
Kiteman
Kiteman
Reply 6 years ago
The copper will deposit wherever the ions are neutralised - it will plate onto any conductor that donates electrons.
Here's a thought for harvesting; line your vessel with a filter, such as a coffee paper or a piece of muslin fabric. You can do your electrolysis, lift out the electrodes, then lift out the filter to contain the solid copper whilst leaving the electrolyte behind.
Orngrimm
Orngrimm
Reply 6 years ago
Problem is still that i dont have a solid piece of sacrificial copper but many scrap-pieces. Tiny ones like 1cm long wire-cuttings...
Thats why i wanted to use a basked of chromesteel (which is connected to the PSU) where i can put the scrap-copper in and dont have to individualy connect them to the PSU.
So the initial question still stands: If i use a chromesteel-basket (connected to the PSU) loaded with copper-scraps, would the basked slowly disolve alongside or instead of the copper?
Kiteman
Kiteman
Reply 6 years ago
Ah...
I have it! Put all the pieces in a porous bag, like a teabag, and feed in a lead from your power supply. The ions are soluble, and will easily migrate through the bag to the other electrode.
Orngrimm
Orngrimm
Reply 6 years ago
Than you for your ideas about the mechanical setup...
But the initial question STILL stands.
Let me rephrase it:
If i have 3 bars with a total of 2 different metals (Copper as Cathode, Chromesteel and Copper as Anode) in a bath with disolved Coppersulfide and run a equal current thru both anodes.... The copper at the anode would be transfered (over ionic transportation) to the Cathode. But what happens with the chromesteel-Anode? Would it also be attacked and loose Iron/Chrome-Ions to the solution?
THATS the question. Not about how to mechanically set it up nor how hight the current and voltage has to be. :) It is a question about electrochemical potentials and ionic soluablity.
I know that copper is less noble (Electrochemically) than chromesteel and we have no iron- nor Chrome-salts in solution. So i think the chromesteel should be rather save as long as we dont apply a voltage bigger than the the minimum neded for the copper to go into an ionic solution. That would be north of a potential-differential of about 0.15-0.2V. Chromesteel should be north of around 6V. So all voltages 0.2-6.0V should be fine and not attack the chromesteel.
Kiteman
Kiteman
Reply 6 years ago
I think you've answered your own question...
Orngrimm
Orngrimm
Reply 6 years ago
Well.... Thats the problem: I THINK i know the answer, but i dont know it for sure... :)
Kiteman
Kiteman
Reply 6 years ago
You have a hypothesis... test ut
Orngrimm
Orngrimm
6 years ago
"But as long as i have copper to be disolved at the cathode," should be ANODE not cathode... Silly me :)
