2093Views3Replies
Author Options:
Does anybody know if a Cutler-Hammer 10250t/91000t switch can handle mains voltage? Answered
It also has A600 and P600 on it. I'm not sure if that means anything though.
NachoMahma
NachoMahma
Best Answer 11 years ago
. Look on the black part at the bottom (the actual switch part) and you should find some specs molded into the plastic. You may need to remove the actuator/operator.There are two screws that enter from the bottom of the switch block.
. You can ignore any numbers on the actuator/operator (the red and chrome parts). These are interchangeable and have nothing to do with the electrical properties of the switch.
. As a rule-of-thumb, most industrial switches like the one you show are rated for at least 250VAC.
. BTW, I think C-H is now a part of Eaton. May make a difference when you search.
Zuma07
Zuma07
Answer 11 years ago
Well I tried what you said and it worked. I didn't think the two parts were made to come apart, so its rated for 6 amps@120 volts and that's all I need. Thank you!
lemonie
lemonie
11 years ago
Probably. Eaton look like they make mains stuff, but I couldn't track down specific voltage / current data for that switch. You could try yourself by Googling "Cutler-Hammer 10250t/91000t switch" but it didn't help me, for as long as I spent clicking links anyway... L
