40502Views29Replies
Author Options:
Does anyone have SOLID information about the Searl Effect Generator? Answered
I have done several searches. It seems to be a closely held data. What I have found is incomplete and sketchy.
flint59
5 days ago
I have a HUGE question:
Can anyone show exactly how HE MADE HIS in the 1960's, and why isn't somebody doing THAT?
Monokheros
4 months ago
The "why" it levitatess: any guesses? Or answers?
Cowboy6Bill9Monokheros
Reply 12 days ago
Generator is, as I understand it, a functional, "zero point node" that creates a warp bubble around itself, thus nullifying gravitational forces around and upon it, I have a working theory I came up with 9yrs.ago that gravity and magnetism are one, the same, and related as well as proportionate.
flint59Cowboy6Bill9
Reply 5 days ago
From my research the SEG forms a torus-shaped and hugely powerful magnetic field that actually negates the effects of gravity that is why it is called the Levity Disk or the Inverse Gravity Vehicle (IGV). Searl flew hundreds of these small disks in the 1960.
MichaelO272
2 years ago
The Searl Effect Generator is almost 6 decades old. If you haven't seen a working model yet, there will probably never be one. He probably got bought out.
Cowboy6Bill9MichaelO272
Reply 12 days ago
After 12yrs. In prison for "Attempted destabilization of the world's economic, monetary and exchange system" (or something like that), I think we can rule out the "...he got bought out!!". Do more research on the man before you open yourself up to criticism, please.
JoblessBroke
1 year ago
Hi, I have been researching the SEG for many years and I have the original transcripts of the SEG that was available at the start of the internet. John Searl, at that time was looking for investors. That information that I have is no longer available on the internet. I believe that John Searl has become old and he has lost a lot of his memory and his notes from that time. If you listen to him very carefully you will realise that he no longer makes much sense.
I wanted to build the SEG using that information but I was never able to get enough funding. The process is extremely expensive. John Searl originally developed the SEG's using the equipment from his employers before he was arrested way back when he first started. I keep all my hard drive and this information is locked in those old hard drives somewhere.
The key to the SEG to work is to create a sine wave of magnetic flux in the plate and the runners. This is done when the magnets are being made. The exact frequency of the sine wave I guess must be the same as the AC current being used in the UK at that time, this would not have changes. As I recall, during the manufacture of the plate and the runners, a DC current is used, but it is interrupted with the AC current for a specific intervals of time during the cooling process to create the sine wave, these intervals have to be precisely timed. (This information is not available and it has to be researched) thus making it a lengthy and expensive process. (My guess would be that the intervals should match the AC frequency that was used at that time)
The principal of operation that was recorded at that time was that, if more than 1 runner was placed on the plate, then the runners could not find a point of rest on the sine wave. The runners (thus named) would chase each other around the plate trying to find the sweet spot of rest. But this sweet spot is always eluding the runners thus the continuous rotation. If you have the funding and are serious about building a replica of the SEG then I would like to be involved and I will make available all the information that I have collected.
Cowboy6Bill9JoblessBroke
Reply 12 days ago
I believe that you will need to have at least a 600v auto-transformer. Converts 220v ac residential electric into as much as 600vdc. This transformer is adjustable 0-600vdc output and required to power the magnetizer, which is necessary to imprint the rollers that move around the rings of the generator. To get the correct shape of the magnetic fields imprinted on each roller and float with the scaler wave without friction around the rings is essential. Still researching it...careful of they, them, those who always watch.
Monokheros
5 months ago
The " impossible to back engineer " does not need to be back engineered.
Searle tells the WHAT needs to happen .. Don't back engineer it ... Do what he tells you to do...
Have fun
AubreyD3
9 months ago
Having found out about this technology recently and researched the material available, I believe it is a genuine concealed technology. The Searl machine is a plasma turbine powered by electron flow rater than water or air flow. The whole area of technology was apparently classified top military secrecy status by the USA military in November 1955 after the court case against John Searl by the electricity company was thrown out of court after they refused to produce the evidence which had been confiscated from his home. The magnetic rings in the illustration below are orientated with the "planetoid" rollers and the central "sun" ring plate having complimentary magnetic Nort South poles which attaches the rollers frimly to the plate. Once in motion, the well known eddy currents induced in the adjacent plate by the movement of the rollers creates a balancing magnetic field which levitates the eollers at a balanced distance from the plate resulting in frictionless bearings. This is the well known principle of the linear motor or maglev train. Magnetic patterns such as thos I illustrated below ensure that the roller rotation is synchronised to their orbits to make exactly 12 rotations on their axes for every orbit of the sun ring.
hamed_sxz
5 years ago
hi
I have done several searches.i don't know how to make generator searls
but i have some clip & documets from the web
if u like all of you and me to share tell me
we have share work and research
fig1a.jpgPrep_illustration_3ring+coils_01.jpgwww searl tripod com.pngseg_craft.jpgNoneNoneseg1.jpgNone
briann121hamed_sxz
Reply 1 year ago
Hi, i know this post is really old. But i just found out about about this genius invention last week and its driving me nuts!! Humanity would be very far if this gem was mass produced! I have to do this experiment! please share what you can....the human race needs you!!
iceng
1 year ago
Self evident !
JonathanC96
3 years ago
For what I understood, it isn't a perpetual motion machine, it converts electron kinetic energy (from heat) into mechanical energy. The logic assertion is, if you have A kCal of heat in the neodymium core, the machine harvest the kinetic energy in the electrons and converts it to B Watts of mechanical energy, that does not violate any physics principle.
And is not "free energy", if someone make the thing work it would generate a certain amount of power as long as the opposing torque (load) equilibrate the torque created by the device. Once the load exceedes the generated power, the machine would loose stability and stop, like any other electric generator.
Maybe is not feasible, maybe it is inefficient, but it is an interesting idea (at least it would make a great cooling method).
RichardeMJonathanC96
Answer 1 year ago
You mean something like the Peltier Effect ... or a kettle?
ajidamo
2 years ago
genuine technologies like searl..does give alot of available research and data outside containment's...there is alot..enough data out there when inquiry is learning and truth and desire to understand searl..I can agree it may be closely set within boundaries among popular sciences and engineering and investments...maybe because of its most advanced and practical evidences of its ability to create free clean energy maybe forever?.. and allowing complete redesigning of previous/current energy and transportation systems currently in use possibly?.. so fast it could maybe alter the ability for that/those preliminary systems which was great advancement for our times..to allow enough time to merge together and maintain orders and be fully harnessed..tested..developed and appropriately understood ..how we can use this for our rapidly changing times and societies..it may be most intimidating at first these technologies....the research and information seems pritty straight forward and simple enough to teach in grade schools even...and alot of info and demonstrations and video and papers books are readily available enough to understand its fundamentals...constructs..abilities and all the practical theory it could offer for human kind..and the earth and planetary explorations even?... to all that would invest and create and generate the means to make it manufactured and functional..then..available for all to enjoy when all the science and engineering is perfected enough for a world that would utilize it wisely and respectively.. i think its a great 'implosive' energy generating alternative/'cure' to current explosive/combustive ways of generating energy needs that seem to be not as effective now in serving our planetary system for longevity in this new age...and even eventually. ..could even introduce levity transportation systems ! ...yes .. talking about our very own levity silver disks parked in your air garages! ... superior mastery and engineering with the most beneficial and logical and reasonable objectives and motives...with materials that are bio friendly and readily available as well...legit... it has submersible qualities too?... i search for that topic...and try to find data on how it works in water...... jason verbelli is great resource to look up or finding out where there may be live demos at tech conventions for example..etc........Searl is Jedi also similar to futurist Jacques Fresco design and engineering systems.. free to all who want to learn it.. build it.. invest and develop to advance the technology further for all to discover.
rickharrisajidamo
Answer 2 years ago
"free energy" is not a thing.
This happens to be true so we need to get over that.
Anyone advertising or claiming to have such a device is selling snake oil. It may look good but it isn't going to work.
As many have said a reasonable postulate is if it worked then it would be in use world wide. It isn't.
There isn't a world wide conspiracy to maintain oil supremacy, The oil companies would welcome getting into a cheap way to produce electricity.
Searl may well be a Jedi - they are fictitious as well.
mateqf90
6 years ago
http://www.rexresearch.com/searl/searl.htm
ahoilett
6 years ago
SOLID no!
As soon as you see books but not parts your on to a losser.
Big Business - of course "The Man" would never allow anyone to start flogging this kinda stuff as it would mess up the world economy as we know it (opps to late).
Scam - most likely your never know for sure till your scammed and then maybe not even then.
Low IQ's - Not really you don't have to have a good IQ to come up with a good idea.
Laws of Physics and Such - Well as much as we think such things are firm HISTORY shows we have a habbit of being sure and wrong at the same time. Not to mention if just by some dumb arse luck you happened to discover something truly advanced it could be indistinguishable from magic, to the point of even what you think (the creator) is going on isn't.
Golden Rule - Don't look to get rich, design, test and publish in all detail for free. Change the world rather than your bank balance then maybe people will believe you.
Shinobi911
7 years ago
Supposedly a gentleman here in San Diego has an operating model. Don't have the time to check it out but I understand he is selective as to whom he allows to see it.
icengShinobi911
Answer 7 years ago
A low IQ on your part might garner you an invite.
steveastrouk
8 years ago
Its woo-woo, effectively another perpetual motion machine.
rickharris
8 years ago
Free energy - No
Pseudo science babble - No
Authentic - No
Anti gravity - No
friction less - No
All round - sorry it's bust no such thing not hidden, not suppressed, just don't work.
orksecurityrickharris
Answer 8 years ago
+1.
If they had anything that worked, they'd patent it so fast you head would spin. If they aren't doing so, that's because it doesn't work.
Period.
verenceorksecurity
Answer 8 years ago
+1
If they had anything that worked they...
a) ..'d turn it into money and got frivolously rich before you could say 'Searl Effect'
you'd would have heard of that (and have already bought the product)
b) 1) would have been contacted by the oil mafia ..err.... industry, (I wanted to say 'industry'!) and get their mouth stuffed with an even more frivolous amount of money to never speak about their findings
or
b) 2) 'd been contacted by said interest group and got their bodies stuffed with some high speed lead particles to make sure they never speak about their findings
In case b, you wouldn't have heard about anything...
So, if you hear about it but can't buy a working sample, that's because there is no working sample.
Double. Period.
iceng
8 years ago
One of these free energy motor generator people setup a demonstration of a small system for 60 people me included looking for deposits to cover semi trailer community power systems. I attended with assurances i could take voltage measurements after the show but I would not be allowed to disconnect wires for placing an ammeter. All agreed to by me....
But then I had a clip-on hall DC current ammeter in my briefcase, which when I set about to clip on caused me to be picked up and removed from the stage in a hurry in front of the local press.
THERE IS NO FREE ENERGY or lunch !!!
A
lemonie
8 years ago
What SOLID information did you want?
"It's a load of bollacks" is pretty SOLID...
L
Kiteman
8 years ago
Have a chuckle: http://searleffect.com/
It will cost you $50 to see the actual "evidence", though.
orksecurityKiteman
Answer 8 years ago
Interesting: He called his device a "levity disk". Yes, levity is the semantic opposite of gravity, but the most common meaning of that word is "humor". Makes me wonder whether he's been too clever by half and has unintentionally acknowledged that this is a scam.
