966Views6Replies
Does anyone have a 28 LED Diagram Using Photocell & NPN Transistor?
I am new at electronic engineering but i just have a few questions about a diagram i tested which seems to work, but i rather more opinions to ensure my transistor, or leds, or resistors, or anything else doesn't burn out but last.
Can someone advise me if i need to change any resistors? I need some guidance please. Thank you for the help, its really appreciate. In the future i may be downgrading to 5MM LEDs...Red & White. When i do downgrade, will i need to replace my resistors? MY circuit is in parallel..Should it be a good idea to switch to a Series Circuit instead?
7 years ago
The all-up running current for the LEDs is 120mA will the transistor handle that ????
Answer 7 years ago
i was thinking if it could, but the LEDs manage to work, but i need to make sure the transistor doesn't burn out. Do i need to add a resistor between the transistor and the negative side of the LEDs?
Answer 7 years ago
It depends entirely on the transistor, if it can handle the current.
7 years ago
Looks fine.
Answer 7 years ago
Ok so this looks ok and will work just fine? If i downgrade to 5MM LEDs i would have to switch my resistors correct?
Answer 7 years ago
yes. If you have any doubts use an LED calc online.
