54296Views10Replies
Author Options:
Does anyone have a pattern for cutting a flat surface and shaping it into a sphere (or hemispere)? Answered
I'd like to make a sheet metal ball, maybe two inches in diameter. I've seen on "how they make it" (or some show) that they die cut paper for globes and then form the cut paper over a cardboard hemisphere. The paper is die cut in a pattern so that the cut pieces come together to form the hemisphere with no creasing or folding. I've googled with no answers (at least that I could find). Thank you! Steve
kgstew
kgstew
3 years ago
Found this searching for a solution to the same problem.
http://www.3dgeography.co.uk/make-a-globe
joemed
joemed
8 years ago
If you have photoshop - here is an awesome filter that makes multiple different gores for sphere cut outs. It also creates fish eye and a long list of other cool effects.
http://www.flamingpear.com/flexify.html
There is a try before you buy and you can test the effect.
enjoy
joe
apriluk
apriluk
11 years ago
Fig. 18, Gores of a Globe
Hi There, Do you mean something like this? It should be easy to calculate the sizes you want from this sort of squashed globe map template using maths explained web site to get the right formulae etc, Also an image like this would be relatively easy to cut out in sheet metal as it doesnt have too many fiddly bits, I have resized the image above when I copied it into this advert and probably lost the correct proportions but I searched on world globe map etc to get this image, looks as though you could probably break it down further into 12 identical pieces if you wanted, and I bet the maths tutorials sites would walk you through the size calculations if you are as hopeless at maths as I am. Hope thia helps,
mikeasaurus
mikeasaurus
12 years ago
Another option would be to find a ball approximately the same diameter that you desire and cut it open adding notches until it's flat. Reverse engineering. From there you'll have your pattern. Hope this helps!
8bit
8bit
12 years ago
Perhaps you could do research into globe projections.
