101Views7Replies
Author Options:
Does anyone have tried to use a bicycle transmission for a multi-speed mechoui ? Answered
I have an AC motor at 4RPM and I do not want to change the sprockets manually each time to change the speed. I would like to have a mechoui (bbq) which allows to have the following speeds: 4, 6, and 8 RPM. I think modifying a transmission of a bicycle: to change the speed I would just have to actuate the handle. What do you think ?
Downunder35m
Downunder35m
4 years ago
Ceratinly possible but two cones that you push together will change the ratio as well and might be less hassle to build.
OlivierM4
OlivierM4
Answer 4 years ago
I'm interested, do you have a draw or something ?
Downunder35m
Downunder35m
Answer 4 years ago
Just check how a scooter transmission works ;)
And instead uf using centrifugal forces and weights to push the wheels apart make it adjustable by screw or bolts...
OlivierM4
OlivierM4
Answer 4 years ago
It seems more difficult to build than to machine new gears to remplace the gears in an 3 speeds bike gear...
rickharris
rickharris
Answer 4 years ago
DU means something like this. Click to see full size.
Remember a standard 3 speed bike gear will only give you:
1:0.75
1:1
1:1.25
gear ratios.
iceng
iceng
4 years ago
Lego can do it
OlivierM4
OlivierM4
Answer 4 years ago
Sure, but not when working close to a fire...
